jking4020
- Year and Model: 1997 850, 2001 v70xc
- Been thanked: 3 times
I finally repaired my 2001 Volvo V70 XC wagon throttle body. Or electronic throttle module. After I tried to open it and messed it up. Curiosity killed the cat and it killed my throttle body. Anyway if anyone else has had this problem with an 01 model get a hold of me it's not too hard to fix.
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I discovered a leak in the windshield. Found it. Easy fix to get done after 3 days of scorching hot sun. Heads up though...I might be ready to sell this soon...as well as my Honda. I want something with no TB or premium gas requirements. Something I dont feel pressured to fix all by myself. Keep an eye out for a listing for this car. It is kinda ugly but loaded and reliable.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 1611 times
- Been thanked: 4075 times
Braced my self for one hour in heat and managed to get her timed. Then went inside, faint from heat.
Went inside and replaced that wanky circuit breaker on kitchen side
- Has thanked: 2210 times
No wonder those breakers a 'wanky' more like 'wonky' Half of them are upside down............!
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
If I ever actually get to Gothenberg one day...
...and happen to run across the engineer who designed the oil cooler line clamp, somebody will have to hold my beer, because there's gonna be a scuffle.
Ooofla, up early to catch the pre 85F window and try to get the exhaust manifold on Elizabeth the T5.
ZionXIX wrote: 04 Sep 2023, 06:41 Will do. Thanks guys. I'm justva little nervous about my first head rebuild ever. But I have 2 wagons in need of head rebuilds waiting after this so the next one should go much quicker.
Zion, two small c clamps mid head will draw down the head easily. I actually prefer this method as I don’t like having spark plug holes open once the head is on. Once the head is down, eight bolts into the number 2 and number 4 cylinders will hold it down fine. Then zip in the other 35. Not very tight, the anaerobic sealer does the sealing work
Most put down too much sealer just a pea dab every 10 cm or so, then rolled to a film. You DONT need a bead like an RTV application
FYI the tension comes from intake 2 and exhaust 5 when the cams are at their marks on the RN engine, see pictures.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Thanks abscate. I ended up splurging for the kit that clamps the valve cover using the spark plug holes abd has the cam alignment tool. It was only $50 on amazon. I see a hefty amount of that aircraft sealant on your exhaust cam sealabscate wrote: 07 Sep 2023, 04:16ZionXIX wrote: 04 Sep 2023, 06:41 Will do. Thanks guys. I'm justva little nervous about my first head rebuild ever. But I have 2 wagons in need of head rebuilds waiting after this so the next one should go much quicker.
