FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Got home from the hospital and wanted to cry... see classsifieds
Current Volvos:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
FLXC90 wrote: 27 Aug 2018, 16:09 Got home from the hospital and wanted to cry... see classsifieds
Good luck with the sale, sounds like a great car! I hope all is well!
Pushi
Year and Model: 1997 v70 2.5T
Has thanked: 2 times
Post by Pushi »
Just took a picture on my friends drive 😉
Jaybar
Year and Model: 95,97 850
Post by Jaybar »
Trying to put fog lamps in I know where the relays go but not sure where the plug is on dash LOL and it's a 95 850. Do I focus on the left side of steering and will it be marked in English.
bmdubya1198
The plug for the switch? It should be the one directly to the right of the headlight knob.
sventastic
Year and Model: 1996 854R
Been thanked: 6 times
Post by sventastic »
jvl wrote: 23 Aug 2018, 09:52 That looks fantastic, Sventastic!
Thank you! The new orbital polisher has already paid for itself I think!
1996 854R | M56H | 16T | 274k | BC, Canada
FLXC90
Post by FLXC90 »
bmdubya1198 wrote: 27 Aug 2018, 17:44
You have thw GLT and the R, round out the set? 16T for the GLT, 18t for the T5 plus your your r
Current Volvos:
bmdubya1198
FLXC90 wrote: 28 Aug 2018, 13:38 You have thw GLT and the R, round out the set? 16T for the GLT, 18t for the T5 plus your your r
Haha, if I could afford to buy another car I would! I'm currently trying to unload the 740 to fund finishing up the R.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Turned a $500.00 Mechanics Special, a 2003 S40 with 110,000 miles, into a running car with $130.00 worth of parts and a $145.00 tow. Slipped timing belt, it slipped just enough to create a crank but no start condition but, no interference damage.
Root cause. the tab on the tensioner broke and the tensioner moved .. this is why one should check the timing belt tension periodically. Snapped belts are not the only thing that can go wrong. Catching a problem early can save a engine.
Active
Past
bmdubya1198
Wow, you lucked out big time! Well done!
