hello
Is there any chance to get this programm?
Code: Select all
CPU Maximum Frequency: 600000000
CPU Frequency: 600000000
Execution Rate: 600 cycles/us
PIN bytes to measure: 3
Number of samples: 100
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
Can't find part number on CAN-LS, trying CAN-HS at 500 Kbps
CAN high-speed init done.
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=cb 50 b9 f0 00 00 00 00
CAN_HS <--- ID=0100082c data=08 00 00 00 00 00 00 59
CAN_HS <--- ID=0110483c data=08 20 a0 00 44 66 e4 00
CAN_HS <--- ID=1a200020 data=82 00 00 00 00 00 01 60
CAN_HS <--- ID=1ae0092c data=c0 00 22 e0 40 00 00 00
CAN_HS <--- ID=1b700030 data=05 00 00 00 00 00 00 00
CAN_HS <--- ID=1ba0493c data=13 00 00 00 00 00 00 00
CAN_HS <--- ID=1be0493c data=01 00 13 bd ea fb 02 04
CAN_HS <--- ID=00400003 data=8f 50 f9 f0 00 30 72 89
CAN_HS <--- ID=0110483c data=08 20 20 00 44 66 e4 00
CAN_HS <--- ID=00400003 data=09 06 20 20 20 30 72 89
Part Number: 30728906
Searching P/N 30728906 in 49 known CEMs
CAN HS baud rate: 500000
PIN shuffle order: 0 1 2 3 4 5
Putting all ECUs into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Initialization done.
Calculating bytes 0-2
1000 pins in 703 ms, 1422 pins/s, average response: 151 us, histogram 75 to 226 us
us: 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162
[ 00 -- -- -- -- -- ]: 0 1191 0 57 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 : latency 1409332; std 385.40
[ 01 -- -- -- -- -- ]: 1 3925 1 1209 0 63 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1429416; std 389.47
[ 02 -- -- -- -- -- ]: 0 3910 0 1140 0 60 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1428868; std 380.18
[ 03 -- -- -- -- -- ]: 4 3925 0 1198 0 70 0 0 0 1 0 0 0 0 0 0 0 0 0 0 : latency 1429380; std 383.03
[ 04 -- -- -- -- -- ]: 0 3571 0 1028 0 57 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1426861; std 372.23
[ 05 -- -- -- -- -- ]: 2 3992 0 1184 0 61 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429435; std 386.68
[ 06 -- -- -- -- -- ]: 2 3822 0 1165 0 56 0 0 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1428856; std 386.40
[ 07 -- -- -- -- -- ]: 0 3931 0 1220 0 57 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1429450; std 381.50
[ 08 -- -- -- -- -- ]: 1 3001 0 765 0 40 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1422683; std 364.90
[ 09 -- -- -- -- -- ]: 2 3937 0 1202 0 64 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1429469; std 386.39
[ 10 -- -- -- -- -- ]: 0 1751 0 277 0 9 0 0 0 1 0 0 0 0 0 0 0 0 0 0 : latency 1413722; std 368.62
[ 11 -- -- -- -- -- ]: 0 3931 0 1223 0 64 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1429419; std 381.67
[ 12 -- -- -- -- -- ]: 0 3852 0 1201 0 56 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1428840; std 373.00
[ 13 -- -- -- -- -- ]: 1 3922 0 1196 0 73 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429463; std 381.39
[ 14 -- -- -- -- -- ]: 4 3518 0 1060 0 50 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1426741; std 368.72
[ 15 -- -- -- -- -- ]: 1 3934 0 1232 0 60 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1429463; std 384.17
[ 16 -- -- -- -- -- ]: 0 3803 0 1173 0 71 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1428836; std 379.47
[ 17 -- -- -- -- -- ]: 0 3951 0 1191 0 76 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429426; std 380.82
[ 18 -- -- -- -- -- ]: 0 2921 0 796 0 48 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1422667; std 358.72
[ 19 -- -- -- -- -- ]: 0 3907 0 1193 0 70 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429423; std 384.59
[ 20 -- -- -- -- -- ]: 0 3955 1 1221 0 53 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429465; std 390.05
[ 21 -- -- -- -- -- ]: 2 3348 2 3913 0 1202 0 50 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449260; std 388.22
[ 22 -- -- -- -- -- ]: 0 3387 0 3832 0 1201 0 54 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448978; std 378.99
[ 23 -- -- -- -- -- ]: 0 3295 2 3969 0 1191 0 53 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449340; std 384.61
[ 24 -- -- -- -- -- ]: 0 3438 2 3618 1 1029 0 52 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1446941; std 374.99
[ 25 -- -- -- -- -- ]: 2 3357 1 3870 0 1226 0 53 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449291; std 384.52
[ 26 -- -- -- -- -- ]: 1 3311 6 3930 0 1155 0 57 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449003; std 382.86
[ 27 -- -- -- -- -- ]: 0 3310 1 3944 0 1184 0 60 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449298; std 386.17
[ 28 -- -- -- -- -- ]: 3 3689 2 2955 0 782 0 35 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1442761; std 366.97
[ 29 -- -- -- -- -- ]: 1 3344 0 3884 1 1217 0 54 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449310; std 384.86
[ 30 -- -- -- -- -- ]: 1 3874 1 1792 0 284 0 12 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1433790; std 374.48
[ 31 -- -- -- -- -- ]: 1 3287 0 3975 1 1178 0 60 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449370; std 386.84
[ 32 -- -- -- -- -- ]: 1 3319 0 3874 0 1179 0 65 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1448981; std 378.27
[ 33 -- -- -- -- -- ]: 0 1453 0 3491 1 3718 1 983 0 13 0 0 0 0 0 0 0 1 0 0 : latency 1466982; std 383.24
[ 34 -- -- -- -- -- ]: 1 3473 1 3550 0 1075 0 39 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1446946; std 376.17
[ 35 -- -- -- -- -- ]: 0 3349 0 3877 0 1207 0 66 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449316; std 380.13
[ 36 -- -- -- -- -- ]: 0 3248 1 3890 0 1199 0 54 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1448931; std 379.09
[ 37 -- -- -- -- -- ]: 0 3348 1 3891 0 1208 0 60 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449481; std 381.02
[ 38 -- -- -- -- -- ]: 2 3666 2 2951 0 818 1 29 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1442755; std 366.10
[ 39 -- -- -- -- -- ]: 1 3350 0 3905 1 1224 0 50 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449386; std 385.92
[ 40 -- -- -- -- -- ]: 0 3813 0 1179 0 59 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1428873; std 385.23
[ 41 -- -- -- -- -- ]: 2 3878 1 1221 0 67 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1429492; std 385.15
[ 42 -- -- -- -- -- ]: 3 3381 3 3833 0 1164 0 64 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1448924; std 385.64
[ 43 -- -- -- -- -- ]: 1 3288 0 3957 1 1193 0 71 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1449444; std 385.67
[ 44 -- -- -- -- -- ]: 0 3413 1 3582 0 1048 0 49 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1446887; std 370.98
[ 45 -- -- -- -- -- ]: 2 3341 1 3906 0 1208 0 66 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449423; std 385.44
[ 46 -- -- -- -- -- ]: 2 3334 2 3860 0 1178 0 53 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448902; std 383.00
[ 47 -- -- -- -- -- ]: 0 3296 0 3921 0 1230 0 55 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449446; std 380.54
[ 48 -- -- -- -- -- ]: 2 3578 0 2995 0 780 0 40 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1442636; std 360.53
[ 49 -- -- -- -- -- ]: 0 3378 1 3891 0 1228 0 54 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449411; std 383.94
[ 50 -- -- -- -- -- ]: 1 3981 0 1693 0 287 0 10 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1433741; std 371.55
[ 51 -- -- -- -- -- ]: 1 3276 1 3945 0 1225 0 56 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449461; std 387.16
[ 52 -- -- -- -- -- ]: 1 3347 0 3812 1 1194 0 58 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1448847; std 383.22
[ 53 -- -- -- -- -- ]: 1 3317 2 3923 1 1238 0 51 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449529; std 390.01
[ 54 -- -- -- -- -- ]: 2 3377 0 3591 1 1041 0 47 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1446821; std 372.50
[ 55 -- -- -- -- -- ]: 1 3296 0 3978 0 1205 0 52 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449491; std 385.35
[ 56 -- -- -- -- -- ]: 0 3363 1 3838 2 1180 0 59 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448915; std 382.83
[ 57 -- -- -- -- -- ]: 0 3296 0 3962 1 1205 0 56 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449481; std 384.61
[ 58 -- -- -- -- -- ]: 0 3616 1 2952 0 806 0 31 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1442627; std 358.77
[ 59 -- -- -- -- -- ]: 0 3316 1 3938 0 1229 0 46 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449432; std 386.22
[ 60 -- -- -- -- -- ]: 0 3917 0 1213 0 62 0 0 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1429445; std 385.60
[ 61 -- -- -- -- -- ]: 3 3337 0 3929 1 1180 0 57 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449310; std 386.85
[ 62 -- -- -- -- -- ]: 0 3359 0 3861 0 1176 0 70 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449012; std 378.92
[ 63 -- -- -- -- -- ]: 1 3349 3 3909 0 1192 0 63 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449336; std 385.90
[ 64 -- -- -- -- -- ]: 1 3473 2 3555 1 1054 0 51 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1446943; std 378.38
[ 65 -- -- -- -- -- ]: 1 3356 0 3905 1 1194 0 59 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449344; std 386.35
[ 66 -- -- -- -- -- ]: 0 3299 0 3878 0 1201 0 53 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449030; std 380.49
[ 67 -- -- -- -- -- ]: 0 3331 2 3922 0 1189 0 58 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449337; std 386.46
[ 68 -- -- -- -- -- ]: 0 3635 1 2971 0 797 0 38 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1442747; std 361.90
[ 69 -- -- -- -- -- ]: 3 3388 3 3846 0 1208 0 65 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449228; std 384.03
[ 70 -- -- -- -- -- ]: 1 3936 0 1763 0 297 0 10 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1433855; std 368.98
[ 71 -- -- -- -- -- ]: 1 3384 1 3872 0 1220 0 64 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449398; std 385.28
[ 72 -- -- -- -- -- ]: 0 3318 0 3933 0 1146 0 63 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448996; std 380.98
[ 73 -- -- -- -- -- ]: 0 3334 2 3903 0 1207 0 60 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449358; std 385.15
[ 74 -- -- -- -- -- ]: 0 3439 1 3597 0 1026 0 59 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1446973; std 374.77
[ 75 -- -- -- -- -- ]: 1 3331 2 3938 0 1176 0 71 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449371; std 384.16
[ 76 -- -- -- -- -- ]: 0 3274 1 3872 0 1202 0 52 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1448947; std 379.26
[ 77 -- -- -- -- -- ]: 1 3375 1 3898 1 1211 0 52 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1449391; std 388.99
[ 78 -- -- -- -- -- ]: 1 3620 2 2998 2 788 0 30 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1442717; std 366.75
[ 79 -- -- -- -- -- ]: 0 3313 0 3920 1 1201 0 60 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449353; std 383.10
[ 80 -- -- -- -- -- ]: 1 3570 1 1062 0 43 0 0 0 1 0 0 0 0 0 0 0 0 0 0 : latency 1426877; std 375.02
[ 81 -- -- -- -- -- ]: 0 3926 1 1219 0 50 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429445; std 386.65
[ 82 -- -- -- -- -- ]: 3 3838 0 1181 0 60 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1428881; std 383.89
[ 83 -- -- -- -- -- ]: 1 3976 0 1201 0 65 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1429459; std 383.03
[ 84 -- -- -- -- -- ]: 2 3446 2 3546 0 1048 0 55 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1446833; std 372.51
[ 85 -- -- -- -- -- ]: 0 3303 2 3946 0 1200 0 68 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1449482; std 381.63
[ 86 -- -- -- -- -- ]: 1 3364 0 3822 0 1198 0 52 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1448914; std 380.30
[ 87 -- -- -- -- -- ]: 0 3271 0 3957 1 1206 0 60 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449431; std 383.35
[ 88 -- -- -- -- -- ]: 1 3580 0 2936 0 831 0 28 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1442615; std 356.74
[ 89 -- -- -- -- -- ]: 0 3222 1 3962 0 1236 0 50 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449419; std 381.87
[ 90 -- -- -- -- -- ]: 0 3933 0 1778 0 265 0 8 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1433908; std 364.22
[ 91 -- -- -- -- -- ]: 2 3313 1 3937 0 1201 0 63 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449397; std 383.55
[ 92 -- -- -- -- -- ]: 1 3313 3 3904 1 1151 0 64 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1448931; std 385.92
[ 93 -- -- -- -- -- ]: 0 3346 2 3903 1 1207 0 65 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1449385; std 385.29
[ 94 -- -- -- -- -- ]: 2 3521 1 3529 0 1033 0 59 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1446899; std 374.89
[ 95 -- -- -- -- -- ]: 0 3310 2 3879 0 1245 0 61 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449402; std 380.81
[ 96 -- -- -- -- -- ]: 0 3340 1 3847 0 1167 0 63 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1448895; std 382.90
[ 97 -- -- -- -- -- ]: 1 3299 0 3914 2 1237 0 51 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1449435; std 382.47
[ 98 -- -- -- -- -- ]: 1 3617 1 2960 0 799 0 29 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1442607; std 363.40
[ 99 -- -- -- -- -- ]: 1 3362 0 3852 0 1274 0 42 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1449409; std 379.63
best candidates ordered by latency:
0: 33 lat = 1466982
1: 53 lat = 1449529
2: 55 lat = 1449491
3: 85 lat = 1449482
4: 57 lat = 1449481
95: 14 lat = 1426741
96: 08 lat = 1422683
97: 18 lat = 1422667
98: 10 lat = 1413722
99: 00 lat = 1409332
best candidates ordered by std:
0: 20 std = 390.05
1: 53 std = 390.01
2: 01 std = 389.47
3: 77 std = 388.99
4: 21 std = 388.22
95: 68 std = 361.90
96: 48 std = 360.53
97: 58 std = 358.77
98: 18 std = 358.72
99: 88 std = 356.74
lat_k 0-1 1.20%, lat_k 98-99 0.31%, lat_k 0-99 4.09%
std_k 0-1 0.01%, std_k 98-99 0.56%, std_k 0-99 9.34%
STD has more deviation than latency
STD[99] deviates more than STD[0]
pin[0] choose candidate: 88 based on std
[ 88 00 -- -- -- -- ]: 4 3911 0 3366 0 182 0 0 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1441097; std 395.73
[ 88 01 -- -- -- -- ]: 1 3916 0 3415 0 194 0 0 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1441377; std 397.14
[ 88 02 -- -- -- -- ]: 0 1917 1 3991 1 3328 0 187 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1460994; std 396.32
[ 88 03 -- -- -- -- ]: 0 1908 0 3996 0 3406 0 186 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461500; std 396.15
[ 88 04 -- -- -- -- ]: 2 2136 1 3999 0 2973 0 153 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1459029; std 386.77
[ 88 05 -- -- -- -- ]: 0 1836 0 3986 2 3427 0 184 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1461379; std 398.92
[ 88 06 -- -- -- -- ]: 0 1908 3 3987 2 3331 0 182 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1460957; std 398.13
[ 88 07 -- -- -- -- ]: 0 1959 1 3964 1 3384 0 196 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461420; std 398.54
[ 88 08 -- -- -- -- ]: 1 2702 1 3906 1 2189 0 118 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1454589; std 374.56
[ 88 09 -- -- -- -- ]: 0 1859 1 4143 0 3301 0 189 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461377; std 400.79
[ 88 10 -- -- -- -- ]: 2 3579 2 3605 0 825 0 35 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1445746; std 381.57
[ 88 11 -- -- -- -- ]: 0 1948 0 4062 0 3346 0 181 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1461428; std 398.17
[ 88 12 -- -- -- -- ]: 0 2022 0 4030 1 3252 0 190 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1460945; std 397.74
[ 88 13 -- -- -- -- ]: 1 1970 1 3971 1 3354 0 198 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461299; std 401.88
[ 88 14 -- -- -- -- ]: 0 2197 0 4000 0 2900 1 166 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1458759; std 383.06
[ 88 15 -- -- -- -- ]: 0 1922 1 4096 3 3296 0 198 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461358; std 401.17
[ 88 16 -- -- -- -- ]: 1 1939 0 4070 2 3257 0 188 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1460955; std 398.22
[ 88 17 -- -- -- -- ]: 0 1855 2 4071 1 3342 0 187 0 0 0 1 0 0 0 0 0 0 0 0 : latency 1461291; std 402.36
[ 88 18 -- -- -- -- ]: 0 2721 0 3873 0 2230 0 120 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1454820; std 368.13
[ 88 19 -- -- -- -- ]: 2 1829 2 4054 1 3358 0 204 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1461354; std 403.31
[ 88 20 -- -- -- -- ]: 0 4028 1 3380 0 194 0 0 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1441510; std 400.52
[ 88 21 -- -- -- -- ]: 0 1872 0 3968 0 3431 0 186 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461408; std 398.92
[ 88 22 -- -- -- -- ]: 0 1947 0 3906 0 3380 0 183 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1460990; std 390.43
[ 88 23 -- -- -- -- ]: 1 1870 0 4013 0 3400 0 194 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1461531; std 398.05
[ 88 24 -- -- -- -- ]: 0 2202 1 4002 0 2934 0 168 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1459057; std 384.89
[ 88 25 -- -- -- -- ]: 0 1928 0 3891 1 3476 0 177 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461469; std 398.23
[ 88 26 -- -- -- -- ]: 0 1941 2 3994 2 3316 1 189 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461017; std 400.65
[ 88 27 -- -- -- -- ]: 0 1890 1 4031 0 3395 1 186 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1461522; std 401.35
[ 88 28 -- -- -- -- ]: 0 2673 2 3964 0 2151 0 131 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1454602; std 373.42
[ 88 29 -- -- -- -- ]: 0 1898 0 4104 2 3332 0 188 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1461494; std 400.86
[ 88 30 -- -- -- -- ]: 2 3600 0 3562 0 843 0 28 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1445684; std 380.77
[ 88 31 -- -- -- -- ]: 0 1896 0 4042 0 3385 0 172 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1461408; std 399.69
[ 88 32 -- -- -- -- ]: 0 1968 1 4036 0 3255 0 197 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1460913; std 394.64
[ 88 33 -- -- -- -- ]: 0 1850 2 4076 0 3348 0 191 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1461318; std 398.55
[ 88 34 -- -- -- -- ]: 0 2215 0 3990 1 2902 0 167 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1458791; std 383.12
[ 88 35 -- -- -- -- ]: 1 1921 1 4144 1 3298 0 185 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1461433; std 408.29
[ 88 36 -- -- -- -- ]: 0 2047 0 4000 1 3273 0 183 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1460957; std 397.68
[ 88 37 -- -- -- -- ]: 0 1950 1 3966 0 3376 1 194 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461338; std 400.11
[ 88 38 -- -- -- -- ]: 1 2619 1 3975 0 2203 0 117 0 0 0 0 0 1 0 0 0 0 0 0 : latency 1454846; std 374.35
[ 88 39 -- -- -- -- ]: 1 1990 1 3829 0 3466 0 194 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461388; std 395.56
[ 88 40 -- -- -- -- ]: 0 1989 0 3979 2 3319 0 189 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461076; std 397.00
[ 88 41 -- -- -- -- ]: 1 1898 1 3897 0 3455 0 184 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461352; std 396.71
[ 88 42 -- -- -- -- ]: 0 487 2 1836 2 4076 1 3331 0 170 0 0 0 0 0 0 0 0 0 1 : latency 1481017; std 401.60
[ 88 43 -- -- -- -- ]: 0 439 0 1905 0 3996 0 3388 0 204 0 0 0 0 0 0 0 1 0 0 : latency 1481628; std 392.93
[ 88 44 -- -- -- -- ]: 0 565 0 2241 2 3996 0 2926 0 173 0 0 0 0 0 0 0 0 0 1 : latency 1479082; std 387.37
[ 88 45 -- -- -- -- ]: 1 445 0 1922 3 3948 2 3421 0 190 0 0 0 0 0 0 0 1 0 0 : latency 1481430; std 402.57
[ 88 46 -- -- -- -- ]: 0 488 1 1957 0 3968 1 3323 0 195 0 0 0 0 0 0 0 0 0 1 : latency 1481034; std 397.82
[ 88 47 -- -- -- -- ]: 0 476 0 1898 2 3950 0 3459 0 166 0 0 0 0 0 0 0 0 0 1 : latency 1481466; std 398.06
[ 88 48 -- -- -- -- ]: 0 923 1 2687 1 3889 0 2208 0 119 0 0 0 0 0 1 0 0 0 0 : latency 1474634; std 373.89
[ 88 49 -- -- -- -- ]: 0 420 0 1936 1 4065 1 3348 0 180 0 0 0 0 0 0 0 0 0 1 : latency 1481450; std 404.38
[ 88 50 -- -- -- -- ]: 0 1530 2 3612 1 3585 0 820 0 39 0 0 0 1 0 0 0 0 0 0 : latency 1465727; std 382.02
[ 88 51 -- -- -- -- ]: 0 420 0 1866 0 4134 1 3333 0 175 0 0 0 0 0 0 0 0 0 1 : latency 1481399; std 403.97
[ 88 52 -- -- -- -- ]: 0 500 0 1961 1 4010 0 3290 0 179 0 0 0 0 0 0 0 1 0 0 : latency 1480899; std 394.79
[ 88 53 -- -- -- -- ]: 0 465 0 1922 2 3993 0 3372 0 187 0 0 0 0 0 0 0 0 0 1 : latency 1481306; std 398.78
[ 88 54 -- -- -- -- ]: 0 656 0 2171 3 3969 1 2934 0 160 0 0 0 0 0 0 0 1 0 0 : latency 1478780; std 384.21
[ 88 55 -- -- -- -- ]: 0 420 0 1981 0 4029 3 3343 0 182 0 0 0 0 0 0 0 0 0 1 : latency 1481403; std 399.04
[ 88 56 -- -- -- -- ]: 0 442 1 2018 1 4011 0 3283 0 183 0 0 0 1 0 0 0 0 0 0 : latency 1480990; std 400.08
[ 88 57 -- -- -- -- ]: 1 427 0 1901 2 4046 1 3371 0 177 0 0 0 0 0 0 0 0 0 1 : latency 1481358; std 405.39
[ 88 58 -- -- -- -- ]: 2 851 1 2704 1 3925 0 2225 1 111 0 0 0 0 0 0 0 1 0 0 : latency 1474853; std 378.92
[ 88 59 -- -- -- -- ]: 0 467 0 1893 1 3936 0 3436 0 190 0 0 0 0 0 0 0 1 0 0 : latency 1481388; std 397.76
[ 88 60 -- -- -- -- ]: 1 1853 0 4089 0 3362 0 191 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1461511; std 400.24
[ 88 61 -- -- -- -- ]: 0 455 1 1909 1 3953 0 3414 0 194 0 0 0 0 0 0 0 1 0 0 : latency 1481400; std 398.05
[ 88 62 -- -- -- -- ]: 0 475 1 1989 2 3948 0 3331 0 182 0 0 0 0 0 0 0 0 0 1 : latency 1480947; std 397.85
[ 88 63 -- -- -- -- ]: 0 448 0 1855 0 4071 0 3377 0 191 0 0 0 0 0 0 0 1 0 0 : latency 1481546; std 397.91
[ 88 64 -- -- -- -- ]: 0 612 0 2170 2 4005 1 2933 0 170 0 0 0 0 0 0 0 1 0 0 : latency 1478983; std 388.28
[ 88 65 -- -- -- -- ]: 0 475 0 1980 1 3788 1 3498 0 195 0 0 0 0 0 1 0 0 0 0 : latency 1481420; std 396.78
[ 88 66 -- -- -- -- ]: 1 460 0 1927 3 3976 0 3338 0 188 0 0 0 0 0 0 0 1 0 0 : latency 1480942; std 398.01
[ 88 67 -- -- -- -- ]: 0 446 0 1941 1 3948 1 3413 0 193 0 0 0 0 0 0 0 0 0 1 : latency 1481470; std 398.60
[ 88 68 -- -- -- -- ]: 0 912 1 2668 2 3926 0 2180 0 118 0 0 0 0 0 0 0 1 0 0 : latency 1474531; std 374.34
[ 88 69 -- -- -- -- ]: 0 439 0 1918 4 4052 1 3344 0 190 0 0 0 0 0 0 0 1 0 0 : latency 1481419; std 400.83
[ 88 70 -- -- -- -- ]: 0 1601 2 3553 0 3600 0 829 0 30 0 0 0 0 0 1 0 0 0 0 : latency 1465714; std 379.06
[ 88 71 -- -- -- -- ]: 0 444 0 1882 1 4110 0 3331 0 180 0 0 0 0 0 0 0 1 0 0 : latency 1481411; std 400.84
[ 88 72 -- -- -- -- ]: 0 472 0 1978 1 4050 3 3260 0 177 0 0 0 0 0 0 0 1 0 0 : latency 1480914; std 398.26
[ 88 73 -- -- -- -- ]: 0 467 0 1867 3 4075 2 3355 0 174 0 0 0 0 0 0 0 1 0 0 : latency 1481331; std 403.61
[ 88 74 -- -- -- -- ]: 0 642 0 2181 1 3970 0 2913 0 176 0 0 0 0 0 0 0 0 0 1 : latency 1478765; std 381.33
[ 88 75 -- -- -- -- ]: 0 449 0 1871 0 4060 2 3371 0 180 0 0 0 0 0 0 0 0 0 1 : latency 1481402; std 399.38
[ 88 76 -- -- -- -- ]: 0 468 0 1973 3 4045 0 3257 1 186 0 0 0 0 0 1 0 0 0 0 : latency 1480918; std 397.60
[ 88 77 -- -- -- -- ]: 0 462 0 1936 3 3980 4 3361 0 192 0 0 0 0 0 1 0 0 0 0 : latency 1481273; std 397.74
[ 88 78 -- -- -- -- ]: 0 895 1 2696 1 3906 1 2212 0 122 0 0 0 0 0 0 0 1 0 0 : latency 1474803; std 375.20
[ 88 79 -- -- -- -- ]: 0 500 0 1900 2 3864 1 3484 0 181 0 0 0 0 0 0 0 1 0 0 : latency 1481357; std 398.38
[ 88 80 -- -- -- -- ]: 1 2253 1 3938 0 2961 0 166 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1459046; std 385.83
[ 88 81 -- -- -- -- ]: 0 1881 0 4002 0 3389 0 208 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461490; std 396.87
[ 88 82 -- -- -- -- ]: 1 1953 0 3982 1 3325 0 184 0 0 0 0 0 0 0 1 0 0 0 0 : latency 1460973; std 398.59
[ 88 83 -- -- -- -- ]: 1 1930 0 3985 1 3396 1 201 0 0 0 0 0 0 0 0 0 1 0 0 : latency 1461567; std 401.68
[ 88 84 -- -- -- -- ]: 0 595 0 2196 0 4013 0 2906 0 181 0 0 0 0 0 0 0 1 0 0 : latency 1478966; std 384.01
[ 88 85 -- -- -- -- ]: 0 475 0 1838 0 4042 1 3376 0 198 0 0 0 0 0 0 0 0 0 1 : latency 1481415; std 399.77
[ 88 86 -- -- -- -- ]: 0 508 2 1969 1 3915 3 3343 0 191 0 0 0 0 0 0 0 0 0 1 : latency 1480942; std 398.07
[ 88 87 -- -- -- -- ]: 0 448 0 1845 3 4050 1 3395 0 192 0 0 0 0 0 0 0 1 0 0 : latency 1481552; std 403.41
[ 88 88 -- -- -- -- ]: 0 959 1 2645 2 3882 0 2219 0 121 0 0 0 0 0 1 0 0 0 0 : latency 1474615; std 370.23
[ 88 89 -- -- -- -- ]: 0 428 0 1917 2 4105 0 3293 0 194 0 0 0 0 0 1 0 0 0 0 : latency 1481328; std 399.45
[ 88 90 -- -- -- -- ]: 1 1546 1 3578 0 3614 0 813 0 35 0 0 0 0 0 0 0 1 0 0 : latency 1465726; std 382.12
[ 88 91 -- -- -- -- ]: 1 435 0 1934 0 4045 1 3348 0 182 0 0 0 0 0 0 0 0 0 1 : latency 1481374; std 398.98
[ 88 92 -- -- -- -- ]: 0 477 0 1965 1 4053 3 3253 0 193 0 0 0 0 0 0 0 1 0 0 : latency 1480990; std 397.74
[ 88 93 -- -- -- -- ]: 0 479 2 1918 2 3962 1 3396 0 182 0 0 0 0 0 0 0 0 0 1 : latency 1481291; std 400.12
[ 88 94 -- -- -- -- ]: 0 608 0 2162 3 4057 0 2886 0 165 0 0 0 0 0 0 0 1 0 0 : latency 1478815; std 384.90
[ 88 95 -- -- -- -- ]: 0 437 0 1848 1 4189 0 3281 0 186 0 0 0 0 0 0 0 0 0 1 : latency 1481395; std 402.44
[ 88 96 -- -- -- -- ]: 0 418 0 1987 1 4097 1 3222 0 197 0 0 0 0 0 1 0 0 0 0 : latency 1481130; std 397.29
[ 88 97 -- -- -- -- ]: 0 445 0 1882 1 4045 1 3355 0 187 0 0 0 0 0 0 0 0 0 1 : latency 1481272; std 401.97
[ 88 98 -- -- -- -- ]: 1 848 1 2712 2 3894 0 2218 0 127 0 0 0 1 0 0 0 0 0 0 : latency 1474766; std 376.92
[ 88 99 -- -- -- -- ]: 0 438 0 1837 1 4057 2 3369 0 205 0 0 0 0 0 0 0 0 0 1 : latency 1481455; std 400.12
0: 43 lat = 1481628
1: 87 lat = 1481552
2: 63 lat = 1481546
3: 67 lat = 1481470
4: 47 lat = 1481466
95: 10 lat = 1445746
96: 30 lat = 1445684
97: 20 lat = 1441510
98: 01 lat = 1441377
99: 00 lat = 1441097
0: 35 std = 408.29
1: 57 std = 405.39
2: 49 std = 404.38
3: 51 std = 403.97
4: 73 std = 403.61
95: 68 std = 374.34
96: 48 std = 373.89
97: 28 std = 373.42
98: 88 std = 370.23
99: 18 std = 368.13
lat_k 0-1 0.01%, lat_k 98-99 0.02%, lat_k 0-99 2.81%
std_k 0-1 0.72%, std_k 98-99 0.57%, std_k 0-99 10.91%
STD[0] deviates more than STD[99]
pin[1] choose candidate: 35 based on std
[ 88 35 00 -- -- -- ]: 0 1510 2 3223 0 3411 0 1386 0 68 0 0 0 1 0 0 0 0 0 0 : latency 1467937; std 355.68
[ 88 35 01 -- -- -- ]: 1 831 1 2723 0 4060 0 2083 0 122 0 0 0 0 0 1 0 0 0 0 : latency 1474658; std 379.26
[ 88 35 02 -- -- -- ]: 1 926 1 2767 2 3923 0 2081 0 120 0 0 0 0 0 1 0 0 0 0 : latency 1474170; std 377.56
[ 88 35 03 -- -- -- ]: 0 859 1 2741 0 4023 0 2102 0 116 0 0 0 0 0 1 0 0 0 0 : latency 1474651; std 378.54
[ 88 35 04 -- -- -- ]: 0 1092 1 2980 0 3710 0 1865 0 101 0 0 0 1 0 0 0 0 0 0 : latency 1472121; std 365.08
[ 88 35 05 -- -- -- ]: 0 879 1 2681 0 4065 0 2108 0 106 0 0 0 0 0 1 0 0 0 0 : latency 1474647; std 376.98
[ 88 35 06 -- -- -- ]: 1 933 0 2760 1 3954 0 2072 0 113 0 0 0 1 0 0 0 0 0 0 : latency 1474180; std 376.89
[ 88 35 07 -- -- -- ]: 0 1344 1 2866 2 3516 2 1723 0 97 0 0 0 0 0 0 0 1 0 0 : latency 1469725; std 352.35
[ 88 35 08 -- -- -- ]: 0 319 0 1533 0 3257 1 3400 0 1358 0 77 0 0 0 0 0 1 0 0 : latency 1487901; std 359.11
[ 88 35 09 -- -- -- ]: 0 131 0 867 0 2740 1 4024 0 2108 0 110 0 1 0 0 0 0 0 0 : latency 1494643; std 381.05
[ 88 35 10 -- -- -- ]: 0 672 0 2295 1 3788 0 2592 0 502 0 23 0 0 0 1 0 0 0 0 : latency 1479133; std 364.39
[ 88 35 11 -- -- -- ]: 0 135 0 865 0 2701 0 4060 1 2098 0 121 0 0 0 0 0 0 0 1 : latency 1494739; std 379.19
[ 88 35 12 -- -- -- ]: 0 169 0 888 1 2770 1 3998 2 2048 1 110 0 0 0 1 0 0 0 0 : latency 1494215; std 383.26
[ 88 35 13 -- -- -- ]: 0 163 0 845 3 2694 2 4049 1 2110 0 120 0 0 0 0 0 1 0 0 : latency 1494722; std 382.65
[ 88 35 14 -- -- -- ]: 0 213 1 1118 0 2883 1 3766 0 1898 0 90 0 0 0 1 0 0 0 0 : latency 1492274; std 367.57
[ 88 35 15 -- -- -- ]: 0 134 1 890 0 2687 0 4027 0 2136 0 108 0 0 0 1 0 0 0 0 : latency 1494703; std 377.96
[ 88 35 16 -- -- -- ]: 0 137 0 920 0 2769 1 3965 0 2082 0 112 0 0 0 0 0 1 0 0 : latency 1494339; std 376.03
[ 88 35 17 -- -- -- ]: 0 155 0 865 2 2652 1 4082 0 2120 0 103 0 0 0 0 0 1 0 0 : latency 1494673; std 381.47
[ 88 35 18 -- -- -- ]: 0 350 0 1483 1 3257 2 3350 0 1442 0 63 0 0 0 0 0 1 0 0 : latency 1488045; std 356.93
[ 88 35 19 -- -- -- ]: 0 131 0 872 2 2699 0 4036 1 2130 0 106 0 0 0 0 0 0 0 1 : latency 1494709; std 378.65
[ 88 35 20 -- -- -- ]: 1 881 0 2688 2 4057 1 2097 0 121 0 0 0 1 0 0 0 0 0 0 : latency 1474714; std 382.93
[ 88 35 21 -- -- -- ]: 0 150 0 882 1 2652 0 4050 2 2142 0 106 0 0 0 0 0 1 0 0 : latency 1494739; std 378.09
[ 88 35 22 -- -- -- ]: 0 136 0 951 0 2677 1 4045 2 2055 0 111 0 0 0 0 0 1 0 0 : latency 1494283; std 378.97
[ 88 35 23 -- -- -- ]: 0 148 0 850 2 2689 1 4053 0 2138 0 100 0 0 0 0 0 1 0 0 : latency 1494723; std 383.72
[ 88 35 24 -- -- -- ]: 0 202 0 1056 1 2980 0 3799 0 1826 0 102 0 0 0 1 0 0 0 0 : latency 1492269; std 369.04
[ 88 35 25 -- -- -- ]: 0 149 0 809 0 2752 1 4061 1 2092 0 116 0 0 0 0 0 1 0 0 : latency 1494746; std 380.68
[ 88 35 26 -- -- -- ]: 0 132 0 930 0 2779 1 3925 1 2102 0 108 0 0 0 0 0 1 0 0 : latency 1494274; std 374.62
[ 88 35 27 -- -- -- ]: 0 152 0 837 0 2700 1 4092 1 2086 0 114 0 0 0 0 0 1 0 0 : latency 1494716; std 380.59
[ 88 35 28 -- -- -- ]: 1 325 0 1502 1 3235 0 3410 0 1398 0 70 0 0 0 0 0 1 0 0 : latency 1488050; std 358.59
[ 88 35 29 -- -- -- ]: 0 130 0 866 1 2700 1 4058 0 2105 0 117 0 0 0 0 0 1 0 0 : latency 1494738; std 379.26
[ 88 35 30 -- -- -- ]: 0 672 0 2317 1 3840 0 2535 0 493 0 26 0 0 0 1 0 0 0 0 : latency 1479045; std 363.91
[ 88 35 31 -- -- -- ]: 1 122 0 905 0 2718 2 3998 0 2132 0 104 0 0 0 0 0 1 0 0 : latency 1494621; std 379.63
[ 88 35 32 -- -- -- ]: 0 152 0 920 1 2794 2 3914 1 2095 0 107 0 0 0 0 0 0 0 0 : latency 1494186; std 376.42
[ 88 35 33 -- -- -- ]: 0 139 0 874 1 2731 1 4005 1 2123 0 105 0 0 0 1 0 0 0 0 : latency 1494593; std 379.96
[ 88 35 34 -- -- -- ]: 0 230 0 1114 0 2903 0 3765 0 1861 0 99 0 0 0 1 0 0 0 0 : latency 1492134; std 360.47
[ 88 35 35 -- -- -- ]: 0 147 0 887 0 2722 2 4010 2 2108 0 114 0 0 0 0 0 1 0 0 : latency 1494618; std 377.38
[ 88 35 36 -- -- -- ]: 0 146 0 945 1 2740 0 3981 0 2067 0 103 0 0 0 0 0 1 0 0 : latency 1494155; std 373.40
[ 88 35 37 -- -- -- ]: 0 132 0 895 3 2703 3 4014 0 2122 0 109 0 0 0 1 0 0 0 0 : latency 1494618; std 379.54
[ 88 35 38 -- -- -- ]: 1 365 0 1502 1 3235 0 3417 0 1377 0 68 0 0 0 0 0 1 0 0 : latency 1487956; std 358.73
[ 88 35 39 -- -- -- ]: 0 139 1 872 0 2762 1 3947 0 2163 0 95 0 0 0 0 0 1 0 0 : latency 1494572; std 381.05
[ 88 35 40 -- -- -- ]: 1 903 0 2776 0 3949 1 2077 0 120 0 0 0 1 0 0 0 0 0 0 : latency 1474278; std 374.86
[ 88 35 41 -- -- -- ]: 0 841 2 2743 0 3999 0 2144 0 110 0 0 0 0 0 1 0 0 0 0 : latency 1474774; std 376.06
[ 88 35 42 -- -- -- ]: 0 163 0 935 1 2716 1 3995 0 2058 0 119 0 0 0 0 0 1 0 0 : latency 1494224; std 377.22
[ 88 35 43 -- -- -- ]: 0 133 0 868 0 2723 2 4009 1 2134 0 113 0 0 0 0 0 1 0 0 : latency 1494751; std 377.99
[ 88 35 44 -- -- -- ]: 0 211 0 1068 1 2904 3 3877 2 1808 0 96 0 0 0 0 0 1 0 0 : latency 1492294; std 372.29
[ 88 35 45 -- -- -- ]: 0 144 1 850 1 2746 1 4019 0 2108 0 118 0 0 0 0 0 0 0 1 : latency 1494707; std 382.95
[ 88 35 46 -- -- -- ]: 0 155 0 895 1 2768 0 3983 0 2068 0 113 0 0 0 0 0 1 0 0 : latency 1494287; std 374.17
[ 88 35 47 -- -- -- ]: 0 134 0 854 0 2736 1 4049 0 2083 0 126 0 0 0 0 0 0 0 1 : latency 1494725; std 379.37
[ 88 35 48 -- -- -- ]: 0 358 1 1479 1 3242 1 3422 0 1378 0 73 0 0 0 1 0 0 0 0 : latency 1488007; std 361.12
[ 88 35 49 -- -- -- ]: 0 124 1 904 0 2713 2 3994 0 2136 0 116 0 0 0 0 0 1 0 0 : latency 1494881; std 374.88
[ 88 35 50 -- -- -- ]: 0 696 1 2251 2 3865 0 2547 0 494 0 22 0 0 0 1 0 0 0 0 : latency 1479037; std 366.05
[ 88 35 51 -- -- -- ]: 0 165 0 845 3 2728 1 3985 0 2140 0 116 0 0 0 0 0 0 0 1 : latency 1494658; std 376.52
[ 88 35 52 -- -- -- ]: 0 165 0 922 1 2719 0 4006 0 2059 0 112 0 0 0 1 0 0 0 0 : latency 1494197; std 375.76
[ 88 35 53 -- -- -- ]: 0 152 0 867 0 2745 3 3988 1 2115 1 115 0 0 0 0 0 1 0 0 : latency 1494597; std 381.27
[ 88 35 54 -- -- -- ]: 0 231 0 1079 0 2954 1 3772 0 1838 0 103 0 0 0 0 0 1 0 0 : latency 1492181; std 366.75
[ 88 35 55 -- -- -- ]: 0 151 1 865 0 2731 0 3995 0 2128 0 111 0 0 0 1 0 0 0 0 : latency 1494599; std 379.35
[ 88 35 56 -- -- -- ]: 0 152 0 939 1 2702 0 4032 1 2037 0 116 0 0 0 1 0 0 0 0 : latency 1494184; std 378.44
[ 88 35 57 -- -- -- ]: 0 139 0 885 1 2710 0 4028 1 2099 0 117 0 0 0 0 0 1 0 0 : latency 1494590; std 379.88
[ 88 35 58 -- -- -- ]: 1 353 0 1481 0 3268 0 3405 0 1373 0 72 0 0 0 0 0 1 0 0 : latency 1487945; std 359.21
[ 88 35 59 -- -- -- ]: 0 141 0 877 1 2773 0 3976 3 2096 0 122 0 0 0 0 0 0 0 1 : latency 1494578; std 376.86
[ 88 35 60 -- -- -- ]: 0 874 0 2643 1 4113 0 2072 0 121 0 1 0 0 0 0 0 0 0 0 : latency 1474647; std 377.34
[ 88 35 61 -- -- -- ]: 0 137 0 895 0 2732 0 3960 0 2139 0 116 0 1 0 0 0 0 0 0 : latency 1494584; std 373.41
[ 88 35 62 -- -- -- ]: 0 162 0 920 0 2719 1 4022 0 2046 0 110 0 0 0 0 0 1 0 0 : latency 1494165; std 374.17
[ 88 35 63 -- -- -- ]: 0 135 0 890 0 2742 1 3953 1 2146 0 112 0 0 0 0 0 1 0 0 : latency 1494608; std 377.98
[ 88 35 64 -- -- -- ]: 0 237 0 1080 2 2907 2 3808 0 1849 0 85 0 0 0 0 0 1 0 0 : latency 1492114; std 369.36
[ 88 35 65 -- -- -- ]: 0 146 1 861 0 2722 1 4031 0 2105 0 116 0 0 0 0 0 0 0 1 : latency 1494654; std 378.35
[ 88 35 66 -- -- -- ]: 0 147 0 937 4 2730 0 4000 0 2050 0 110 0 0 0 0 0 1 0 0 : latency 1494144; std 375.73
[ 88 35 67 -- -- -- ]: 0 139 1 862 0 2733 4 4026 1 2107 0 108 0 0 0 0 0 1 0 0 : latency 1494622; std 380.76
[ 88 35 68 -- -- -- ]: 0 357 1 1465 1 3252 0 3433 0 1353 0 83 0 1 0 0 0 0 0 0 : latency 1487952; std 361.42
[ 88 35 69 -- -- -- ]: 0 131 0 886 0 2730 0 4027 0 2101 0 108 0 0 0 1 0 0 0 0 : latency 1494590; std 374.24
[ 88 35 70 -- -- -- ]: 1 705 0 2261 2 3851 0 2554 1 495 0 26 0 0 0 0 0 1 0 0 : latency 1479144; std 368.16
[ 88 35 71 -- -- -- ]: 0 147 2 864 0 2718 0 3988 2 2150 0 115 0 0 0 1 0 0 0 0 : latency 1494744; std 379.05
[ 88 35 72 -- -- -- ]: 0 152 1 911 2 2749 3 3969 0 2082 0 113 0 0 0 1 0 0 0 0 : latency 1494284; std 379.62
[ 88 35 73 -- -- -- ]: 0 126 0 886 0 2732 0 3982 0 2152 0 106 0 0 0 1 0 0 0 0 : latency 1494714; std 375.26
[ 88 35 74 -- -- -- ]: 0 213 0 1096 2 2931 1 3779 0 1866 0 88 0 0 0 0 0 1 0 0 : latency 1492245; std 367.18
[ 88 35 75 -- -- -- ]: 0 165 0 830 1 2717 2 4014 0 2151 0 106 0 0 0 1 0 0 0 0 : latency 1494747; std 378.20
[ 88 35 76 -- -- -- ]: 0 164 0 939 0 2679 1 4006 0 2082 0 115 0 0 0 0 0 1 0 0 : latency 1494297; std 372.76
[ 88 35 77 -- -- -- ]: 0 129 0 880 3 2742 0 4014 0 2106 0 115 0 0 0 1 0 0 0 0 : latency 1494677; std 378.39
[ 88 35 78 -- -- -- ]: 1 338 0 1484 3 3285 1 3401 0 1364 0 79 0 0 0 1 0 0 0 0 : latency 1488016; std 364.33
[ 88 35 79 -- -- -- ]: 0 140 0 834 1 2815 1 3933 0 2149 0 115 0 0 0 0 0 0 0 1 : latency 1494736; std 379.43
[ 88 35 80 -- -- -- ]: 0 1063 0 2923 1 3844 0 1835 0 84 0 0 0 1 0 0 0 0 0 0 : latency 1472243; std 369.59
[ 88 35 81 -- -- -- ]: 0 857 1 2730 0 4005 0 2141 0 109 0 0 0 0 0 1 0 0 0 0 : latency 1474731; std 378.15
[ 88 35 82 -- -- -- ]: 0 897 0 2725 0 4015 0 2064 0 118 0 0 0 1 0 0 0 0 0 0 : latency 1474316; std 376.47
[ 88 35 83 -- -- -- ]: 0 870 0 2721 1 3965 1 2165 0 113 0 0 0 0 0 1 0 0 0 0 : latency 1474718; std 378.24
[ 88 35 84 -- -- -- ]: 0 216 0 1054 0 2971 1 3813 1 1799 0 115 0 0 0 0 0 1 0 0 : latency 1492248; std 368.67
[ 88 35 85 -- -- -- ]: 0 142 0 856 1 2755 0 3971 0 2145 0 117 0 0 0 0 0 0 0 1 : latency 1494751; std 374.93
[ 88 35 86 -- -- -- ]: 0 158 1 908 0 2688 1 4064 0 2044 0 113 0 0 0 0 0 1 0 0 : latency 1494276; std 379.80
[ 88 35 87 -- -- -- ]: 0 151 1 865 1 2706 0 4020 3 2119 0 125 0 0 0 0 0 1 0 0 : latency 1494767; std 379.61
[ 88 35 88 -- -- -- ]: 0 341 0 1532 1 3243 0 3325 1 1446 0 68 0 0 0 0 0 1 0 0 : latency 1488038; std 355.96
[ 88 35 89 -- -- -- ]: 0 152 0 868 1 2705 1 3993 2 2141 0 121 0 0 0 1 0 0 0 0 : latency 1494722; std 380.71
[ 88 35 90 -- -- -- ]: 0 699 0 2252 1 3862 1 2539 0 496 0 25 0 0 0 1 0 0 0 0 : latency 1479022; std 365.58
[ 88 35 91 -- -- -- ]: 0 152 0 857 0 2742 0 4046 0 2076 0 116 0 0 0 1 0 0 0 0 : latency 1494582; std 377.07
[ 88 35 92 -- -- -- ]: 0 135 1 948 1 2760 1 3941 1 2085 0 110 0 1 0 0 0 0 0 0 : latency 1494224; std 378.88
[ 88 35 93 -- -- -- ]: 0 143 1 877 0 2726 0 4009 0 2109 0 115 0 1 0 0 0 0 0 0 : latency 1494575; std 375.17
[ 88 35 94 -- -- -- ]: 0 229 0 1078 0 2968 2 3749 0 1851 0 95 0 0 0 1 0 0 0 0 : latency 1492112; std 366.33
[ 88 35 95 -- -- -- ]: 0 157 0 842 1 2774 0 3973 0 2126 0 114 0 0 0 1 0 0 0 0 : latency 1494623; std 377.31
[ 88 35 96 -- -- -- ]: 0 155 0 955 0 2769 1 3902 1 2091 0 114 0 0 0 0 0 1 0 0 : latency 1494136; std 374.82
[ 88 35 97 -- -- -- ]: 0 148 1 881 0 2762 0 3907 0 2175 0 114 0 0 0 0 0 1 0 0 : latency 1494653; std 372.35
[ 88 35 98 -- -- -- ]: 0 328 0 1550 1 3178 0 3433 0 1398 0 60 0 0 0 0 0 1 0 0 : latency 1487977; std 353.37
[ 88 35 99 -- -- -- ]: 0 131 0 895 0 2721 1 3991 0 2127 0 111 0 0 0 0 0 1 0 0 : latency 1494589; std 374.58
0: 49 lat = 1494881
1: 87 lat = 1494767
2: 43 lat = 1494751
3: 85 lat = 1494751
4: 75 lat = 1494747
95: 02 lat = 1474170
96: 80 lat = 1472243
97: 04 lat = 1472121
98: 07 lat = 1469725
99: 00 lat = 1467937
0: 23 std = 383.72
1: 12 std = 383.26
2: 45 std = 382.95
3: 20 std = 382.93
4: 13 std = 382.65
95: 18 std = 356.93
96: 88 std = 355.96
97: 00 std = 355.68
98: 98 std = 353.37
99: 07 std = 352.35
lat_k 0-1 0.01%, lat_k 98-99 0.12%, lat_k 0-99 1.84%
std_k 0-1 0.12%, std_k 98-99 0.29%, std_k 0-99 8.90%
pin[2] choose candidate: 07 based on std
Candidate PIN 88 35 07 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 703 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..95%..
PIN is NOT cracked in 2809.39 seconds
done
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00You don't need a camera. Use the key [PrntScn] ( Print Screen ) then look in the folder Pictures\Screenshots\ .
I connect common ground with the OBD-II connector.
I got a 2011 CEM-H to crack. Had to set it to 100 samples. That was the first Frankenstein CEM.
The 2004 V70 is a CEM-B. The side attack does not work on a CEM-B.urosm wrote: 25 Jul 2021, 09:36
I tried cracker on 2004 V70 and 2005 V70. Both D5.
This schematic I used:
