I finally today remember check and yes straps there. I was still remembering my previous car after all these years.. weird.
RedBrickCollector
- Year and Model: 1997 850 T-5 Wagon
- Has thanked: 40 times
- Been thanked: 29 times
Going further down my odometer/speedometer diagnosis and looks like my harness ends at the speed sensor are gone. Are the speed sensors polarized?
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
- cmblackburn
- Year and Model: 1998 S70 T5M
- Has thanked: 1 time
- Been thanked: 7 times
Finally figured out the excessive blow by in Honey Badger, caused by a faulty EGR solenoid. Formerly 94TurboMom (Tiana's) car...given to my wife and I as a wedding present for us to fix up together. Really loving this car
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Did you find a new EGR solenoid? I think the EGR valve itself is NLA.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Used my S70 to shave a dead deer. It was dead in the road, and already been hit a few times. Didn't look that big, so I figured I'd straddle it with the car. The car is lower than I tend to think of it as being. Grossness now exists on the bottom side. I also dented the intercooler lower tank. I don't think any real damage occurred, but I'll be visiting the car wash again soon.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- cmblackburn
Planning on just deleting it. For now I disconnected the vacuum line from the intake, the solenoid and the valve itself are both NLA. I have a ‘96 intake manifold for it, just need to figure out blocking off the EGR pipe from the exhaust manifold and find a ‘96 non SAS/EGR ECU.BlackBart wrote: 20 Feb 2024, 19:05 Did you find a new EGR solenoid? I think the EGR valve itself is NLA.
- Has thanked: 2215 times
- Been thanked: 1853 times
Did 96 cars have non-SAS ECU's? There is the SAS bypass diode you can do. If you can find an ECU, there are guys who can re-program them.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
In the US, I think only the 96-97 NAs and the 97 LPT GLTs had the SAS in the 850's.
You should be able to do the resistor mod for the EGR. I don't recall any EGR on the 96 or 97 HPT turbo motors I've had.
The -072 96-97 HPT(non-R) M4.3 ECU should be what you want, unless you decide to do an M4.4 upgrade and then you can just disable the diagnostics for it. I didn't see anything in the M4.3 bins that I looked into.
- xanthefin
- Has thanked: 106 times
- Been thanked: 130 times
Well i almost ended up making this kind of LAME DEALERSHIP Key chip programmer which only lets you have just so much fun!xanthefin wrote: 05 Feb 2024, 16:17 Almost done writing IMMO key programmer feature after playing on my 850.. noticed a way i can actually produce key chips remotely without being close or touching cars if car is not near me if they have just PIN code for it and send dump for me.
.. thanks Bosch.
Nooo.. i want MORE what Volvo mechanics ever dreamed of have details and capabilities for key programming!
Lets make it not just mechanic level tools but more like ENGINEER LEVEL... i want all bytes! das Auto!
.. Yes lame Bosch IMMO uses pointer technique in how it has keys activated from memory. "Erasing" means on these modules (all IMMO boxes of P80 and P1 Volvos - all years since 1996 (includes models with CDM) ) moving end pointer to one or zero so it will use then first slot just overwriting it but now you can check what was there and manually overwrite any slot or restore them!
I would add configuration bits as well but i am running out of screen real estate here and i think i need move them to another screen another time in future.
Verlog/Vin slot is under maybe or not included as well and in possibility of future expansion.
.. yes you need a PIN code from Volvo or you trigger Security Timer to go up which you need wait to go down to play with this.
If you need a -072 ECU, I have been sorting through a bunch of parts my buddy wants to sell. There is one in this stash.
If you have no luck locally, PM me and I can see if we can get this to you for a reasonable price.
