My first no-start experience today! This winter on the coldest days, I had issues with the starter doing the same thing as at 2:42 in this video :
However, after a couple of attempts, it would start.
Today, I was cranking and cranking successfully, but the car just wouldn't turn over. Suddenly, I got an Anti-Skid Service Required Message on my DIM, and a check engine light. Code revealed to be P0600. Tried cranking 4 or more times. Finally it turned over.
To me, it's evident of a brown out condition that brought down the communication bus, or a module that prevented my start. Battery sits idle at about 12.4 and alternator running I get a steady 14v. Could a bad starter pull the bus down and prevent a start (ironic, I know) ? Will pull VIDA information when I get home from work but I'm not sure it will help me any further.
No start! Com. Bus Storm, P0600 Topic is solved
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
04s60 2.4
04xc70 2.5t
04xc70 2.5t
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
I suspect your battery is pooched-- take it to Canadian Tire for a load test.
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- br0dy519
Load test passed with flying colours. Picked up a starter and will replace tomorrow.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
some guys say to reroute that wire at the same time the starter is out . It runs behind the starter bracket.br0dy519 wrote: 01 Jun 2022, 13:54 Load test passed with flying colours. Picked up a starter and will replace tomorrow.
Is it the crank timing sensor wire ?
Whatever it is , its known to pick up RF from an old sparking starter motor and prevent starts.
- br0dy519
Thanks for clarifying. I thought perhaps you were just referring to that exciter wire with the crimped end. I will keep a look out for any looms that live close to the starter. If anyone has a diagram of the wiring jones is referring to (cn90 I’m looking at you for nice captioned photos!!) please post them for reference.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- br0dy519
Thanks Jones. I was poking around last night and found the following threads
viewtopic.php?t=84343
viewtopic.php?t=35374
viewtopic.php?t=53441
viewtopic.php?t=94176
None had any valid picture links. Thank you for that link with good photos! My cable actually looked very good and solid, attached to the mounting bracket that routes it away from the starter. Even the looms were in good condition. I replaced the starter with a Bosch rebuilt and it's working great today. I'll update in a month and mark as solved if it doesn't happen again.
From my research last night, it looks like hot humid weather can exaggerate any sort of interference issues. With my starter already on it's way out, it was likely generating a ton of EMI on that very hot day a few days ago (~33c dry bulb here), that caused the CANBus to go haywire. Good thing this issue is so well-documented on everyone's favourite Volvo forum- MVS!
04s60 2.4
04xc70 2.5t
04xc70 2.5t
leapdragon
- Year and Model: 2007 XC70
- Has thanked: 12 times
- Been thanked: 31 times
Wow guys, this is both fascinating and helpful. I guess I know what I'm experimenting with this weekend!
- 1272 Views
Last post by bmdubya1198
- 1415 Views
Last post by hanzbe420
- 2093 Views
Last post by - Pete -
- 3339 Views
Last post by chrism
- 6816 Views
Last post by VolvosLocos
