Volvo C70 Lock Alram Control Module Topic is solved
VolvoTR
Year and Model: 1998 C70T
Has thanked: 6 times
Been thanked: 2 times
Post by VolvoTR »
Greetings to everyone, when I bought my vehicle, it did not have a remote control ( 1998 Model ), I bought a 1998 model S70 key, but I could not program it because we did not have a VST device, I am thinking of buying the lock alarm control module from the vehicle from which the remote came. My question is, I get the lock alarm control unit 9459309, is there any problem with the lock alarm control unit 9459480 of the remote? Confusing me, my vehicle is 2 doors, the module I will buy is for a 4 door vehicle. Thank you from now.
SirBrickWagon
Year and Model: 1997 Volvo 850
Has thanked: 7 times
Been thanked: 11 times
Post by SirBrickWagon »
VolvoTR wrote: 06 Jun 2022, 10:48 Greetings to everyone, when I bought my vehicle, it did not have a remote control ( 1998 Model ), I bought a 1998 model S70 key, but I could not program it because we did not have a VST device, I am thinking of buying the lock alarm control module from the vehicle from which the remote came. My question is, I get the lock alarm control unit 9459309, is there any problem with the lock alarm control unit 9459480 of the remote? Confusing me, my vehicle is 2 doors, the module I will buy is for a 4 door vehicle. Thank you from now.
i believe that if you take the relay under the dashboard for the guard alarm (slot 210/211) and pop that into your C70 it should work fine. Robert DIY has a great video on pairing a keyfob to a car as well.
hope this helps!
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
I've looked at the subject on my car (98 V70, built in 97) a few times, and havent found a clear answer. Seller said "ah ye the remotes just need new batteries" :lol:
I have managed to program the immo chip to work with the car, but that doesnt make the remote work.
It does not have a 210/211 relay, and the relay sockets arent even populated.
No remote module behind the glovebox like the older cars, the plug is there but plugging a module doesn't do anything.
My next theory is that without VST you need to find a remote module (the one under the dash, right above the instrument cluster) with matching remotes.
The alarm on my car never worked, it came with an aftermarket one that I removed a while ago. Maybe I haven't found how they deactivated the OEM alarm to let the aftermarket one work.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
SirBrickWagon
Goupil wrote: 07 Jun 2022, 13:25 I've looked at the subject on my car (98 V70, built in 97) a few times, and havent found a clear answer. Seller said "ah ye the remotes just need new batteries" :lol:
yeah it needs a central locking relay and the 210/211 relay in order to pair and use a keyfob.
Has thanked: 1502 times
Been thanked: 3813 times
You usually get immobilizer functions a few years earlier in EU markets vs NA markets so be careful of advice from ABCs….. Angry British Colonists who can’t spell.
VolvoTR
Post by VolvoTR »
SirBrickWagon wrote: 07 Jun 2022, 10:38
hope this helps!
My central locks are working now (trunk, gas tank lid, etc.), only because I didn't have a remote control, I bought a key belonging to the S70 instead of the C70, but I couldn't program it.I'm wondering if it would be okay if I took the module of the car where I bought the S70 controller.the difference of 2 doors and 4 doors is also that the part numbers are different.
SirBrickWagon
VolvoTR wrote: 08 Jun 2022, 06:56
hope this helps!
i would at least give it a shot, pop the relay from the s70 into the c70 and if it doesn't work you can always put it back, no harm in trying!
SirBrickWagon
abscate wrote: 07 Jun 2022, 18:11 You usually get immobilizer functions a few years earlier in EU markets vs NA markets so be careful of advice from ABCs….. Angry British Colonists who can’t spell.
RobertDIY only covers NA market cars from what i've seen but it should be more or less the same?
VolvoTR
Post by VolvoTR »
SirBrickWagon wrote: 08 Jun 2022, 09:43
hope this helps!
Yes , you are right it's worth a try.Thank you.
