2004 XC70
Madtown1101
- Year and Model: 2204 XC70
2004 XC70
Hey all, have a quick question in regards to my Volvo. I have been experiencing rough idle at startup for the past few weeks, but once the car is warm it runs fine. The codes p0420 and p0134 show up. Bought a new car, will be installing this week. Yesterday I went to clean the MAF, it was fine, but I could use a new air filter. I went to start up the car after cleaning the MAF and it wouldn’t even stay idling, very rough then stalled out. Went back under the hood and finally noticed my turbo inlet pipe is completely sheared off at the clamp, on the turbo end. My guess is I finally broke it completely off when I was taking my MAF out. Am I correct in my assumption that replacing this pipe will solve my issues and return to normal drivability? I should also state that the downpipe/cat/sensor are all brand new.
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 53 times
- Been thanked: 62 times
Replacing the intake pipe may not fix all the problems you have but I can guarantee that the car won't run correctly if leaks between the mass airflow sensor and intake valves are not sealed.
The Volvo and aftermarket inlet pipes are extremely expensive. Try getting a part from a u-pick junkyard. I got one for $10 after I found a crack in the bellow section of the pipe on my Magic S60.
Good luck!
David E
2001 Moondust V70
2004 Blue XC70
2007 Silver V70
2007 Magic Blue S60
2007 Titanium S60
Good luck!
David E
2001 Moondust V70
2004 Blue XC70
2007 Silver V70
2007 Magic Blue S60
2007 Titanium S60
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
Madtown1101
Thank you very much!
- 641 Views
Last post by shiloh51933
- 1869 Views
Last post by 01_Nautic_V70
