Coolant leaking. (2002 v70)
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
After fixing multiple leaks I found, the coolant is still disapearing. I can not find any coolant on the ground (maybe im just not looking hard enough), and I can not find a leak. I dont think its the head gasket since I just replaced that, and the exhaust is fine, and there are no bubbles in the coolant resovour like there was before. It also seems that the coolant leaks faster when the car is being driven. How would I go about solving this and finding the leak?
2002 v70 X/C 288k miles
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Do a coolant pressure test.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
+1^
Coolant might seep out on something warm and dry off. Can be really hard to find sneaky leaks. I have recommended a pressure tester several times. Easy peasy. Hf has a kit that works great.
BMW 540i 2002
S70 Base 2000
jonesg
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
block tester fluid.
Jonboy74
Year and Model: V70 2.4T, 2002
Has thanked: 119 times
Been thanked: 15 times
Post by Jonboy74 »
jonesg wrote: 20 Aug 2022, 15:59 block tester fluid.
THAT'S COOL!!!!!
Jonboy
Jonboy74
Post by Jonboy74 »
02V70 wrote: 20 Aug 2022, 12:47 After fixing multiple leaks I found, the coolant is still disappearing. I cannot find any coolant on the ground (maybe im just not looking hard enough), and I cannot find a leak. I don't think it's the head gasket since I just replaced that, and the exhaust is fine, and there are no bubbles in the coolant reservoir like there was before. It also seems that the coolant leaks faster when the car is being driven. How would I go about solving this and finding the leak?
I had a similar issue twice. Once was the radiator, and the other time was the heater core. The radiator had a pinhole and was leaking, but not enough to make a puddle and it was evaporating for the most part.
for the heater core, it had a similar issue, and was leaking into the passenger side floorboard, but I didn't know it because I don't often carry passengers and it wasn't leaking a ton.
So, yeah - pressure test the system!
Jonboy
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Did you ensure you did not have a cracked sleeve/cylinder? That's the last possible reason if it isn't a heater core, which trust me, are a pain in the ass no matter the car. The whole dashboard comes off, the wiring is in the way, the support frame may be in the way, the nuts and bolts outside and inside....
Jonboy74
Post by Jonboy74 »
dikidera wrote: 22 Aug 2022, 06:04 Did you ensure you did not have a cracked sleeve/cylinder? That's the last possible reason if it isn't a heater core, which trust me, are a pain in the ass no matter the car. The whole dashboard comes off, the wiring is in the way, the support frame may be in the way, the nuts and bolts outside and inside....
Ok, yes, the heater core was a pain on my 02 V70 2.4T, but it wasn't THAT bad!?! I did not have to remove the dash.
Jonboy
jonesg
Post by jonesg »
Look for chalky stains on the coolant bottle, the corners of the bottle can crack and leak under pressure but barely leave a trace.
dikidera
Post by dikidera »
Jonboy74 wrote: 26 Aug 2022, 20:02
Jonboy
Trust me I've disassembled many many cars and it's always a pain in the ass to take out the whole unit behind the dashboard. Luckily it's a scrap yard so most of the time I don't have to worry about damaging it, cause it may be going in the bin, however even if I gave it my all, a few bits and nuts may get broken when you think you got them all.
