I have a 1998 S70 Sport. No turbo. A/C had been acting strangely - compressor kicking in, then quickly off, then repeating. Felt like low refrigerant. When the car is cold, pressure in the system is about 80PSI. So it's not empty.
A week ago the ECC was dead, as was the sunroof and instrument panel lights. A 10A fuse blew. Replaced it. Everything else works except the a/c. Blend doors, heat, fans... all good except a/c compressor won't come on.
Low pressure switch is working. Currently reads closed (with 80PSI not running). Shorting the connector changes nothing. Replaced the high pressure switch. No changes. If I short the compressor pins on the a/c relay, the compressor comes on OK, sounds good, gets cold. Replaced a/c relay. No change.
As far as I understand it, there are no other sensors to worry about... it feels like the ECC is the culprit. I removed it. Opened it up. Nothing fried that I can see. My guess is that the cause of the fuse blowing was the ECC, and that the ECC is causing this current headache. But I don't have a spare to play with. I can get on on eBay for about $50, but that's an expensive guess.
Just now I connected a freon recharge kit to the low side. About 85PSI with the engine off, about 80F. Started the car. Shorted the a/c relay pins. Compressor came on. Low side pressure dropped into the 40's then continued into the 20s. THAT feels like low refrigerant, or maybe a blockage? So I let it charge. It started getting cool in the car. After a few minutes I got a hissing noise. Dunno if it was a leak or the clutch slipping. I pulled the jumper. I think it was the clutch slipping. Maybe now I'm overcharged?
I let the car sit a half hour or so. Jumping the clutch relay working OK. compressor sounds OK.
Wish Volvo had put high side ports on this car. I may see if my gauges will connect directly to the Schrader on the high side. Wanna see what the high pressure looks like.
Before I spend that $50 on a used ECC, does anyone have any other ideas? Maybe my replacement high pressure switch is no good, but seems unlikely. I'm stumped.
AC won't kick in...
as400jockey
- Year and Model: V70 T5, 2001
2001 V70 T5; 1998 S70 Sport; 1998 S70 T5 (sold); 2002 S60 (sold); 1980 245 Wagon (crusher - rusted to smithereens); a few others... learned carb fixing at 10 year old on Dad's 1971 144 sedan.
as400jockey
Figured it out...
I replaced the high pressure switch. Nope. The AC relay. Nope. Shorted the low pressure switch. Nope. Replaced the ECC module (in the dash). Nope.
I pulled the ECM, cleaned the contacts, let it sit for a few minutes for any memory to die, reinstalled, and voila! Compressor kicks in now.
Top
Top
- Oly850
- Year and Model: In acquisition mode.
- Has thanked: 53 times
- Been thanked: 22 times
There is such a thing as too low AND too high in these systems. Anything over about 70psi and the high switch will never click off and the compressor won’t run.
Looking for a V90 to be my next Volvo, at the very least a T5.
2017 XC90 Inscription - My best Volvo by far, but Ex-wife departed & I had to sell.
2001 S80 T6 - rebuilt trans, head gasket, fixed & sold
1997 V70 - kid car, sold
1996 850 GLT - found under bridge, 2 year refurb project, commuter car, kid car, T-Boned - SIPS saved passenger. Totaled.
1997 VW GTI VR6 - exceedingly fast.
1971 VW Type II/231 - it was pointed out by management that the children would be killed in it.
- 1850 Views
Last post by Davwatermk
- 19 Replies
- 6202 Views
Last post by as400jockey
- 1499 Views
Last post by MMT51
- 3294 Views
Last post by oragex
- 1030 Views
Last post by oragex
