1996 850 NA Replace Front Oxygen Sensor P0133
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
Got the P0133 code, along with louder exhaust, some say that an exhaust leak can set this code.
Odd, the loud exhaust issue went away since the first time that I looked at it about a month ago,
cleared the code, guessing that it will come back.
Robert DIY shows how to do it here, he uses a slotted O2 sensor socket:
Had the car up on ramps so shot the front O2 sensor with PBlaster and WD40, let it soak in.
I have an O2 socket that is similar to the one that Robert uses but it is Autocraft brand and looks
more like cast iron than steel. It says 7/8" (22mm) on it. It went on all the way, and then when I
used a braker bar on it, it slipped and turned. I seem to remember clamping it tighter with vice
grips the last time that I used it in a spot with enough room. There's not enough room here.
OK, so the nut surface is slightly rounded now. I guess that the thing to do is to get a better
socket and try again. I suppose that a last resort would be to use vice grips on it.
It looks like the Autocraft socket just opened up a bit, I'd avoid this brand in the future.
Suggestions? I could try heat of course but we only have a propane torch.
PeteB
Post by PeteB »
Got a close look at it and it seems that the socket expanded and didn't damage the nut much at all.
I ordered a hopefully better socket and will give it a try with heat.
I do have an open end wrench that held tight but was unable to break it - the new socket is probably
a better bet.
It takes the PBlaster well, looks like it gets sucked right into the threads, but of course has not freed it.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Maybe a pipe wrench ?
1999 V70 GLT
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I had the same problem a while back. The tool is not sturdy enough and finally just opens up and spin. Think I just bought a new one from Autozone. Worked like a charm.
BMW 540i 2002
S70 Base 2000
Has thanked: 1609 times
Been thanked: 4065 times
Heat the snot out of it with propane for 60 seconds, let cool for 10 minutes while you do something else
Repeat
Repeat
I’ve got a couple of these tools if you want to meet on Route 8 somewhere and borrow.
I want to say my black oxide complete 22mm with a breaker bar is the best one I have for this job
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I bought a Tekton socket last year in January (2021), and that worked great -- did not open up or spread noticeably while removing the old O2 sensor. It was a TEKTON 3/8 Inch Drive x 7/8 Inch Offset 6-Point Oxygen Sensor Socket, part number 47749. Only cost $8 at that time, now $11 in Oct 2022.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
I've used a hose clamp on O2 sensor tools, to help keep them from spreading apart for really stubborn sensors.
PeteB
Post by PeteB »
abscate wrote: 18 Oct 2022, 04:30 I’ve got a couple of these tools if you want to meet on Route 8 somewhere and borrow.
Thanks, I have another socket on the way, and will try the heat first then this socket and will let you know if I need to borrow one.
Thanks again.
I have some doors for you by the way, do you still have space to store them?
PeteB
Post by PeteB »
Went to buy the O2 sensor from FCP and this one is listed as the correct one:
https://www.fcpeuro.com/products/volvo- ... -v70-15097
The plug doesn't look like the one that Robert disconnected in his video above.
I noticed that FCP offers an extension cable that DOES look like the plug that Robert worked on:
https://www.fcpeuro.com/products/volvo- ... 14#fitment
Now I just noticed that it says that this fits 1997 850s but ours is a 1996.
The question is if the O2 sensor linked above will fit as is or will some sort of adapter be needed?
I've not gotten the old one out so I don't know what it looks like.
Anyone?
