Getting ready to do some front end work that will require a shade tree alignment. I watched a few vids on the subject, the ones that involve string. But I got to thinking --
given the Front track is 61.1" and Rear is 60.9", giving a difference of 3/16"", and toe in is 1/8" can I simply string a tight line From back of the back tire to the front of the front, and adjust so the line touches the front and rear sidewall of the front tire?
2001 V70T5
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
If your front and rear toe are both off... Regardless, no you must use the center of the wheels from side to side, front and back to establish parallel in order to know where each wheel stands and adjust accordingly.
https://blog.fcpeuro.com/at-home-alignm ... n-your-car
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
I'm just looking to align enough to hold me until I get to the shop. Like a week or so
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Has thanked: 1509 times
- Been thanked: 3827 times
If your tires match you can use a tape measure on the tread to get it close enough to drive locally, a telescoping rod inside. I’ve gotten them close on tie rod end replacements by just counting threads
azureblue
Thanks - I'd forgotten about this one - I used it on a VW I had way back..
I'm getting new tires and alignment in a couple of weeks so I just need "close enough" for now, but close enough for highway driving.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
