04 V70 occasional no crank
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Dave0304XC
Year and Model: 2003 XC70
Been thanked: 3 times
Post by Dave0304XC »
Hello- 2004 V70, 115K miles. About a month ago I was (out of town) and was driving here and there one day. Stopped at a place, and shut her off. Came out and car had dash lights, wipers, windows etc but would not crank. Just a click.
Had it towed to a "european" specialist, said I needed a new battery. Hmmm. With a new battery it started fine. Back home now and Have been driving it every day. Last week it did the same thing again. Dash lights but no crank. Towed to my local european (which I now learn is really just Audi / VW). Of course it cranked fine when they looked at it. They looked it over, said alternator was putting out 14.4 v, starter was cranking fine.
I can't have this thing towed every 3 weeks, any suggestions on this? Dave
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Find a wire that goes to that contact on the starter, take it out, clean thoroughly (scratch with a thin screwdriver, use electric cleaner), put back.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
if cleaning the small terminal doesn't work, try jumping between the 2 terminals on the starter, if it cranks over the problem is upstream, I would look at the ign switch. On my older volvo (740) I installed a push button to start the car, volvo ign swittch was too expensive for me.
I used a 12v feed from the battery POS to the small terminal with momentary switch in between and 15 amp inline fuse.
Hokey but it worked fine.
Has thanked: 1500 times
Been thanked: 3812 times
Dave. I think the P2 has the same starter bypass terminal the p80s do. I’ll check mine tomorrow
