Worn Rotors
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Worn Rotors
Post by 02V70 »
My front rotors on my '02 v70 seem to have a groove with a small amount of metal sticking out on the top and bottom. Since braking is otherwise fine, do the rotors need to be replaced?
Here are some photos:
2002 v70 X/C 288k miles
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
How much brake pad is left?
08 C702.5T (sold)
The non-Swedes:
02V70
Post by 02V70 »
Not much, I'm planning to replace the pads soon.
Has thanked: 1855 times
Been thanked: 1714 times
Volvo and some aftermarket suppliers have a minimum thickness specification for rotors. I have seen Volvo and Brembo sometimes stamping into the metal around the edge of the rotor these values. You may have to wire brush the edge of the rotor to see if it is there.
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 482 times
Post by jonesg »
they appear worn out to me.
Krons
Post by Krons »
02V70 wrote: 11 Jul 2023, 17:53 Not much, I'm planning to replace the pads soon.
I’d replace the pads and rotors then.
Rotors have gotten so inexpensive it’s hard to justify turning the rotors to take that lip off, even if within spec. Very likely those rotors will never live through the next set of pads.
08 C702.5T (sold)
The non-Swedes:
jonesg
Post by jonesg »
I recall paying $36 per disk at AUTOZONE.
cheap enough...not worth messing with.
Has thanked: 1507 times
Been thanked: 3825 times
New 26.0 mm
Wear limit 23.0 mm
Is that both front and rear abscate? I used to have a note about it. I took a 2nd look at the pictures and realized that there was a big lip on them which I missed before but the good keen eyes did not! Yes those will not run another set of pads as has been stated. New Rotors needed.
Year and Model: 2001 V70
Has thanked: 929 times
Been thanked: 1004 times
Post by volvolugnut »
Haynes paper manual agrees - 23 mm wear limit for FRONT Except for 305 mm Diameter brakes. The big brakes wear limit is 25 mm.
Rear wear limit is 10 mm.
