Hi,
My Granddaughter drives a 2007 S40, 2.4. Has been a solid runner but needs a timimg belt. Today I started tearing into it, planning to replace the seals on the cams and crank also, as well as fixing the oil filter housing. I removed the rear cam covers and attempted to remove the "wheel" under the cam position sensor using a T30 torx. I stripped the torx bolt. Does anyone have any ideas how to remove the bolt at this point? I really don't want to replace the belt without doing the cam seals too.
Thanks,
Rick
Cam Position Wheel Bolt Stripped
rhlee222000
- Year and Model: 2007 V70
- Has thanked: 1 time
- IMG_3172.jpg (258.02 KiB) Viewed 632 times
rhlee222000
I thought about this alot. It's not really in a good spot to try and drill it out, our use a screw extractor. If I mess it up, I don't think I have the time nor the skill te replace a broken cam. There doesn't appear to be a huge amount pf oil leaking from the cam seals. I just might replace the oil pump and crank seals, repait the oil filter housing and put the new timimg belt on. The car is only really driven around town and this may be my best choice.
Rick
Rick
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 22 times
This happened to me as well but I just left it for the time being and only did the timing belt and other stuff.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
RobsS40
- Year and Model: 2006 S40 T5 AWD
- Has thanked: 2 times
- Been thanked: 7 times
Another technique I've used: a Dremel (or angle grinder or something similar) with small thin cutting disk. Cut a nice slot in the head and use a regular straight-blade screwdriver- preferably one with a square shank so you can put a wrench on it and get some torque on it.
Some might MIG or TIG a nut or short bolt onto it, but I'm guessing that's not in your bag of tricks.
I don't know- does anyone know if they're left-handed (counterclockwise to tighten) thread bolts?
