Changing the flex joint on a 2007 XC 70...
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
AylmerQc
Year and Model: 2007 XC70
Has thanked: 60 times
Post by AylmerQc »
I dread thinking about doing this job simply due to the fact the bolts and studs for the heat shield and on the header might shear off rather than unscrew.
What's you experience on doing such a job?
The flex joint has a hole approximately 1/4 inch wide by 2 inches long. I'm wondering if using high heat silicone or something similar to patch the hole would work...
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 175 times
Post by dikidera »
Spray them with penetrating oil and let it soak for the day. I had only one or two shear off but those were from the heat shield.
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 482 times
Post by jonesg »
if the heat shield bolts break , toss the stinkin shield.
before diving in ,get something like this to suit your model year,
https://www.fcpeuro.com/Volvo-parts/V70 ... =8642449KT
and a new flex pipe of course, the ones with double liner, accordian inside wall is best.
I think its 2 1/2 inch x 10 inch, not sure, I'm trying to measure mine, I have to get it done in the next 10 days.
are you repairing or swapping the whole thing out.?
I'll be welding a new flex.
