long time reader first time poster
2004 V70 2.5t, 180k
Getting a consistent oil leak from somewhere behind the VVT. reading around the forums seems camshaft seal or worn VVT is the source, back of the VVT is very wet from what I can see. Worn VVT has high in/out play, is it possible to test that by simply loosening tensioner? or do I have to remove timing belt?
maybe at 180k the best thing to do is replace VVT and seals without further diagnosis?
Oil leak upper passenger exhaust side Topic is solved
nliutilitt
- Year and Model: 2004 V70
- Has thanked: 10 times
- jonesg
- Has thanked: 73 times
- Been thanked: 532 times
pull the belt cover and look at the cam seal behind the cvvt hub.
if its still seated properly the vvt O ring might be worn. FCP sells the big green O ring (viton?).
you'll need the rear cam lock tool to remove the center bolt holding the hub to the shaft.
Disconnect battery first. set timing marks to their proper position and remove timing belt.
It requires removing a bunch of stuff at the rear end of the cam shaft. strut tower brace, charge air pipe , assorted brackets.
for the cvvt hub retaining bolt I used a T55 drive , ratchet wrench with a cheater pipe , its around 90 ft lbs.
had to wrestle the wiring harness out of the way to get enough room.
- 881 Views
Last post by willst5
- 25 Replies
- 4452 Views
Last post by xHeart
- 1678 Views
Last post by alschnertz
- 1980 Views
Last post by imckillip
- 13 Replies
- 4783 Views
Last post by nutmegrose
