210k miles. Old mounts seemed bad - car was vibrating terribly. Replaced the mounts with the Hutchinson kit on FCP Euro. They did not include all of the right bolts and nuts, so I re-used some from the mounts I removed.
At first car felt fine, but then it started vibrating again. I dropped it off at mechanic for an exhaust repair and they said they found the mount to be loose and corrected it. I drove a bit and it felt very smooth… then it started vibrating again. I got home and the rear mount was loose again. I get my torque wrench, torque it to spec. Today I drove a mile before it started vibrating again.
I completely uninstalled it, examined it, and found it wholly unremarkable. I just cannot understand why it’s coming loose. I’m using proper torque spec for bolts. Threads seemed fine. What could possibly be causing/enabling this? What are the proper boots/nuts I should use? Idk what else to do at this point. I don’t even understand how this is possible.
05 V70 2.5T: engine mount issues
- 972 Views
Last post by GreenMagicMan
- 1126 Views
Last post by harryhendo
- 16 Replies
- 2998 Views
Last post by Bluevanacd2005
- 1927 Views
Last post by leapdragon
- 9975 Views
Last post by thisisbuod
