I read that a clogged PCV system will create a vacuum at the oil dipstick tube. Under idle at maybe 1K, I get a mild vacuum. At about 97K miles, does this mean I need to replace the PCV valve? Or is a mild vac Ok?
Thanks
testing PCV
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
A rubber glove over the oil fill after removing the cap should suck in toward the engine. Definitely should not inflate, or the pressurized engine will start pushing out seals.
If it fails this test you should change the PCV parts. What engine you have?
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
it's a 2014 S60 t5, 5 cyl., , and this engine does not have a lip to attach a rubber glove to.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Has thanked: 987 times
- Been thanked: 1076 times
Can you use a plastic zip tie to attach a glove to the oil fill opening? Or get a used cap and add a small pipe nipple to the cap?
azureblue
There is no lip to attach anything to - the cap is flush. The dipstick shows a mild vacuum
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Krons
Don’t overthink the glove test, I’ve even laid a plastic shopping bag over the oil fill. If it sucks toward the engine you are good. Just don’t let it suck it into the engine!
You just want to verify it has vacuum and the engine crankcase isn’t pressurized.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
azureblue
Thanks - So if there is a mild vacuum at the dipstick, that is the same a vacuum at the oil filler cap?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Krons
Never heard of folks using the dipstick verify the PCV is functioning. I’d pull off the oil filler cap and double check .azureblue wrote: 01 Nov 2023, 07:29 Thanks - So if there is a mild vacuum at the dipstick, that is the same a vacuum at the oil filler cap?
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 11 Replies
- 2068 Views
Last post by mika
- 672 Views
- 4288 Views
Last post by precopster
- 389 Views
Last post by combatkarl
- 1774 Views
Last post by 5ft24
