2008 3.2 XC70 Hatch Latch lock and unlock issue
Steve H
- Year and Model: 2008 S60 2.5T & XC70
- Has thanked: 6 times
- Been thanked: 10 times
I have a 2008 XC70 that if you unlock the doors with the fob and go to the hatch and try to manually open the latch it is like it is locked and does not engage or pull anything. However if you push the hatch button and let the automatic system open the hatch, then close it. Only then can you use the latch handle to manually open and close the hatch. The reason I am concerned is if the automatic system fails I will not be able to get into my hatch. Has anyone had this problem and have a fix for it? Thank you.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
You can do what I did for my LR2 (note: the modification is based on what was added to the XC70)
https://www.freel2.com/forum/topic36840.html
Also the micro switch is likely similar for your XC70 and my LR2
https://www.freel2.com/forum/topic38799 ... cro+switch
I don't know if Volvo Sweden has posted a video about this on youtube but that is where I would look.
EDIT: I looked
Good Luck
Paul
EDIT: I looked
Good Luck
Paul
