2000 v70
JamesTyler
Year and Model: 1997 v70 glt
2000 v70
Post by JamesTyler »
My buddy has a 2000 v70 automatic that will not move in any gear no dash lights. Originally got the flashing arrow about 2yrs back and replaced the pnp switch then got a scanner on it and it called for a torque converter control solenoid. He just replaced all solenoids and has new trans fluid. Car currently moves on its own when in idle but stops moving when gas pedal is pressed.
Has thanked: 1854 times
Been thanked: 1714 times
Is the car a 4 or 5 speed automatic? Non-turbo V70 it is probably a 5 speed auto, if turbo mostly likely a 4 speed auto with the exception of a V70R which is also a 5 speed auto in 2000.
Depending on the trans, they use different trans oils. Have you used to correct one?
Is the fluid level correct? What you are describing sounds like low fluid?
