'03 v70 Base cranks, no start, no codes, pump's audible
olpossum
Year and Model: 03 V70, 99S70
Post by olpossum »
Went out one morning last week, it cranked but didn't start. The pump ran for about a third of a second, like always when you start it. There's no gas in the fuel rail. 270K miles, pretty original, seems to be the PEM, which I'm not finding. And that removable lid behind the driver's seat, I removed it, and there's nothing else there to remove. Replaced the fuel pressure sensor. Anybody know where the PEM is in this car?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
olpossum wrote: 20 Mar 2024, 12:55 Went out one morning last week, it cranked but didn't start. The pump ran for about a third of a second, like always when you start it. There's no gas in the fuel rail. 270K miles, pretty original, seems to be the PEM, which I'm not finding. And that removable lid behind the driver's seat, I removed it, and there's nothing else there to remove. Replaced the fuel pressure sensor. Anybody know where the PEM is in this car?
probably has no pem.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
olpossum wrote: 20 Mar 2024, 12:55 Anybody know where the PEM is in this car?
Check passenger side of fuel tank near fuel filter.
Active
Past
olpossum
Post by olpossum »
Thanks for the reply, I found it, hidden. Got it out, unseen, with the aid of quite a bit of profanity.
jonesg
Post by jonesg »
olpossum wrote: 23 Mar 2024, 18:07 Thanks for the reply, I found it, hidden. Got it out, unseen, with the aid of quite a bit of profanity.
if the pump primes, the pem is responding.
reading the fuel pressure at the rail is the test i'd do.
olpossum
Post by olpossum »
The fuel pump runs when you turn the key to position II--the one right before it cranks, anyway. I appreciate you responding, this is a problem for me. It appears the fuel pump relay is on a little board up under the dash near the driver's door. Judging by the length of the bundle of wires running to it, it can be removed for access, do you know how it gets released? Can't even get a phone up in there.
jonesg
Post by jonesg »
olpossum wrote: 07 Apr 2024, 13:16 The fuel pump runs when you turn the key to position II--the one right before it cranks, anyway. I appreciate you responding, this is a problem for me. It appears the fuel pump relay is on a little board up under the dash near the driver's door. Judging by the length of the bundle of wires running to it, it can be removed for access, do you know how it gets released? Can't even get a phone up in there.
if its part of the cem there are plenty of youtube videos showing removal.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Cycle the key four times to position two, instead of just one time. Still no fuel pressure at the rail?
olpossum
Post by olpossum »
Checked the fuel pressure with a gauge, no pressure at the rail. Cycled the key 4X, no fuel, no pressure at the rail. I had replaced the fuel pressure sensor. I just removed the PEM & its components, no corrosion found, no evidence of moisture, ever. The sound of the fuel pump is odd, it revs up and then makes a winding-down sound, every time, rather than the normal holding-pressure type abrupt stop.
Has thanked: 1611 times
Been thanked: 4071 times
Did you open the PEM? The corrosion damage is on the inside
See here
viewtopic.php?p=556647&hilit=2005+v70+PEM#p556647
