1998 C70 About SRS lamp
VolvoTR
Year and Model: 1998 C70T
Has thanked: 6 times
Been thanked: 2 times
Post by VolvoTR »
Hello ; When I bought my vehicle, the airbags were deployed and the SRS light was on. When I scanned it with Vol-FCR, it showed an error in the driver airbag, passenger airbag and passenger seat belt (SRS-232 / SRS-221 / SRS-222 / SRS-242). The airbags and dash were repaired. I had a driver airbag from a 1998 model donor vehicle. and I bought a passenger airbag, I also bought a dash from a 1999 or 2000 model vehicle and it came with an airbag. I installed the driver airbag from a 1998 model vehicle and the dash from a 1999/2000 vehicle. When I scanned it again with Vol-FCR, I got the same errors. This time, I tested it by connecting a 2.2 ohm resistor instead of the passenger airbag, but I still got the same warnings. What do you think is the problem? Is my test resistor wrong? (2.2. ohm) Or is it necessary to try installing the passenger airbag from the 98 model instead of the airbag from the 99/00 vehicle? (the sockets are different, I have a socket compatible with both of them, the 98 one is green/white cable and the other one is blue/brown)
Has thanked: 1841 times
Been thanked: 1709 times
The SRS system was changed in North America from 98 to 99 years. The main change was the method of setting the system off when from mechanical to electrical. New airbags appear to be no longer available from Volvo.
Looking at the parts drawings for North America, the dashboard airbag and steering wheel airbags for 99 are not compatible with a 98.
What engine do you have 2.3 or 2.4l and is it a coupe or convertible?
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
scot850 wrote: 20 Mar 2024, 23:15 The SRS system was changed in North America from 98 to 99 years.
I believe that change only applies to the side bags in the front seats.
AFAIK, the steering wheel and passenger dash bags have always
been electrically deployed with squibs.
I don’t know squat about air bag module diagnostics, but my first
thought would be to check into a post-deployment reset procedure.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
As BEJinFbk mentioned after Crash you have Crash data in your SRS module which by over 95% cases wont go away with usual OBD readers but programming.
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 94 times
Been thanked: 39 times
Post by jmartin919 »
These guys may be able to help. https://www.myairbags.com/
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Volvo listed different part numbers for the dash airbag for -98 and 99-
VolvoTR
Post by VolvoTR »
scot850 wrote: 20 Mar 2024, 23:15 The SRS system was changed in North America from 98 to 99 years. The main change was the method of setting the system off when from mechanical to electrical. New airbags appear to be no longer available from Volvo.
Hi , 2.0T5 Engine how i can found test resistor ? 2.2 ohm dosnt work
VolvoTR
Post by VolvoTR »
jmartin919 wrote: 21 Mar 2024, 05:24 These guys may be able to help. https://www.myairbags.com/
Thank you for help but i live Turkey
VolvoTR
Post by VolvoTR »
scot850 wrote: 21 Mar 2024, 08:15 Volvo listed different part numbers for the dash airbag for -98 and 99-
i have 1998 pass airbag i must test.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
xanthefin wrote: 21 Mar 2024, 04:42 ...after Crash you have Crash data in your SRS module which by over 95% cases wont go away with usual OBD readers but programming.
This^^
You can't just replace deployed airbags and expect from system to work.
Crash data from srs module must be erased after airbags replacement to make srs system to work again...or just replace srs module on pre '99 cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
