Fuel Pressure Regulator equivalents
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
EDIT: Parts are listed for Volvo 850s but do not fit my fuel rail. This style is much larger.
Researching the fuel pressure regulator, both N/A And Turbo cars use a 3.0 bar 1:1 rising rate fuel pressure regulator.
For the rail mounted regulator, I couldn't find it on FCP euro, and while digging for where else I could order, I came accross this equivalent part and model application list. Now this is from a chinese company so each part should be validated as you order, but I took a random sample and it seems to check out.
OEM NO.:PR4056 PR4058, PR4087 PR409 PR4120 PR60 RP127002
Bosch: 0 280 160 235, 0 280 160 226, 0 280 160 294, 0 280 160 249, 0 280 160 758, 0280160235, 0280160226, 0280160294, 0280160249, 0280160758
Audi, Seat, VW, : 037133035
Alfa Romeo: 0060513339, 195 36 11 034 00, 6051 33 390, 0605133390
BMW: 13 53 1 284 897, 13 53 1 711 541, 13 53 1 722 040, 13 53 1 284 796, 13 53 1 722 039, 13 53 1 711 540, 13531284897, 13531711541, 13531722040, 13531284796, 13531722039, 13531711540
Citroën/Peugeot: 91 51 526 380, 91 515 263, 95 516 685, 91 51 668 580, 99 99 163 370, 9151526380, 915153693, 95516685, 915
Fiat/Lancia: 60808045, 60611308, 60811469
Ford: X86TF 9P917 01 , X86TF9P91701
Hyundai: 35301 22000, 35301 22002, 3530122000, 3530122002
Renault: 77 00 746 046, 77 00 730 998, 77 00 747 543, 77 00 680 165, 7700746046, 7700730998, 7700747543, 7700680165
Saab: 756 414, 75 64 149, 751 869, 751 868, 756414, 7564149, 751869, 751868
Talbot: A 518 195
Volvo: 1357710, 3517064
Large quantity is acceptable! WHOLESALER WELCOME ,WHOLESALE PRICE.
GUANRANTEE: ONE YEAR.
USE FOR
BMW 318i 1984-1985 1.8L 1766CC 107Cu. In. l4 GAS SOHC Naturally Aspirated
BMW 535i 1985-1993 3.5L 3430CC l6 GAS SOHC Naturally Aspirated
BMW 635CSi 1985-1989 3.5L 3430CC l6 GAS SOHC Naturally Aspirated
BMW 735i 1985-1992 3.5L 3430CC l6 GAS SOHC Naturally Aspirated
BMW L7 1986-1987 3.5L 3430CC l6 GAS SOHC Naturally Aspirated
BMW 325i 1987-1993 2.5L 2494CC 152Cu. In. l6 GAS SOHC Naturally Aspirated
BMW 325i 1992-1993 2.5L 2494CC 152Cu. In. l6 GAS DOHC Naturally Aspirated Valves: 12
BMW 325is 1987-1991 2.5L 2494CC 152Cu. In. l6 GAS SOHC Naturally Aspirated
BMW L6 1987 3.5L 3430CC l6 GAS SOHC Naturally Aspirated
BMW M6 1987-1988 3.5L 3453CC l6 GAS DOHC Naturally Aspirated
BMW 325iX 1988-1991 2.5L 2494CC 152Cu. In. l6 GAS SOHC Naturally Aspirated
BMW 535is 1988 3.5L 3430CC l6 GAS SOHC Naturally Aspirated
BMW 735iL 1988-1992 3.5L 3430CC l6 GAS SOHC Naturally Aspirated
BMW M3 1988-1991 2.3L 2302CC l4 GAS DOHC Naturally Aspirated
BMW M5 1988 3.5L 3453CC l6 GAS DOHC Naturally Aspirated
BMW 525i 1989-1990 2.5L 2494CC 152Cu. In. l6 GAS SOHC Naturally Aspirated
BMW 525iT 1993 2.5L 2494CC 152Cu. In. l6 GAS DOHC Naturally Aspirated
Volvo 740 1985-1992 2.3L 2316CC l4 GAS SOHC Turbocharged Turboo
Volvo 740 1991-1992 2.3L 2316CC l4 GAS SOHC Naturally Aspirated
Volvo 745 1985 2.3L 2316CC l4 GAS SOHC Turbocharged Turboo
Volvo 760 1985-1990 2.3L 2316CC l4 GAS SOHC Turbocharged
Volvo 244 1989 2.3L 2316CC l4 GAS SOHC Naturally Aspirated
Volvo 245 1989 2.3L 2316CC l4 GAS SOHC Naturally Aspirated
Volvo 780 1989-1991 2.3L 2316CC l4 GAS SOHC Turbocharged
Volvo 240 1990-1993 2.3L 2316CC l4 GAS SOHC Naturally Aspirated
Volvo 940 1991-1992 2.3L 2316CC l4 GAS DOHC Naturally Aspirated
Volvo 940 1991-1995 2.3L 2316CC l4 GAS SOHC Turbocharged
Volvo 940 1992-1994 2.3L 2316CC l4 GAS SOHC Naturally Aspirated Engine: B234F
Volvo 850 1993-1995 2.4L 2435CC l5 GAS DOHC Naturally Aspirated
Volvo 850 1994-1995 2.3L 2319CC l5 GAS DOHC Turbocharged Located at Fuel Rail
Saab 9000 1987 2.0L 1985CC l4 GAS DOHC Naturally Aspirated
Volkswagen Golf 1987-1989 1.8L 1780CC l4 GAS DOHC Naturally Aspirated
Volkswagen Golf 1987-1992 1.8L 1780CC l4 GAS SOHC Naturally Aspirated
Volkswagen Golf 1989-1992 1.8L 1781CC 109Cu. In. l4 GAS SOHC Naturally Aspirated
Volkswagen Jetta 1987-1989 1.8L 1780CC l4 GAS DOHC Naturally Aspirated
Volkswagen Jetta 1987-1992 1.8L 1780CC l4 GAS SOHC Naturally Aspirated
Volkswagen Jetta 1987-1992 1.8L 1781CC 109Cu. In. l4 GAS SOHC Naturally Aspirated
Volkswagen Jetta 1988-1992 1.8L 1780CC l4 GAS Naturally Aspirated
Volkswagen Cabriolet 1990-1993 1.8L 1780CC l4 GAS SOHC Naturally Aspirated
Volkswagen Corrado 1990-1992 1.8L 1780CC l4 GAS SOHC Supercharged
Volkswagen Fox 1991-1993 1.8L 1780CC l4 GAS SOHC Naturally Aspirated
Volkswagen Passat 1991-1993 1.8L 1780CC l4 GAS Supercharged
Peugeot 405 1989-1991 1.9L 1905CC l4 GAS DOHC Naturally Aspirated
Peugeot 405 1989-1991 1.9L 1905CC l4 GAS SOHC Naturally Aspirated
Alfa Romeo Spider 1990 2.0L 1961CC 120Cu. In. l4 GAS DOHC Naturally Aspirated
Alfa Romeo 164 1991-1993 3.0L 2959CC V6 GAS SOHC Naturally Aspirated
Hyundai Scoupe 1993-1995 1.5L 1495CC l4 GAS SOHC Naturally Aspirated
Hyundai Scoupe 1993-1995 1.5L 1495CC l4 GAS SOHC Turbocharged
Compatibility is just for reference,please confirm your OE number.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 94 times
Been thanked: 39 times
Post by jmartin919 »
Do you have the Volvo part number?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
jmartin919
Volvo - 9146761
If it works, way cheaper than the OEM (if you can get it) or Delphi stainless steel version. Didn't realize the same one is used on the 850's at the rail as well as the 2000 S70 back at the fuel filter.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
RedBrickCollector
jmartin919 wrote: 17 Jun 2024, 19:33 Volvo - 9146761
I'm not 100% but this looks like it might be the part for cars with the regulator by the steering rack. Someone with experience with one or the other please chime in
'97 950 T-5 Wagon
RedBrickCollector
Quick update: Doing further research, I've come across other posts stating that pre-'96, there are brass spacers/standoffs used. Is it possible that what I have is meant for this style of mounting and are the actual fuel rails the same? Pictures of the spacers and/or part numbers would be great
'97 950 T-5 Wagon
Has thanked: 1850 times
Been thanked: 1712 times
Not quite sure what you are asking. This link shows a injector rail fuel pressure regulator in the top part marked #1.
It shows what looks like some spacers but they are not listed and the whole part is NLA.
https://www.volvocarstorontoparts.ca/a/ ... 73614.html
However in this drawing it looks different:
https://www.volvocarstorontoparts.ca/a/ ... 41923.html
Is this the stuff you are looking for? Sorry that there are no part numbers.
Looking at pictures for 1996 look the same.
Problem is sometimes things are different for different markets. Like we never got 2 liter engines here, only 2.3 and 2.5.
coop
Year and Model: 1998 s70 t5
Has thanked: 17 times
Been thanked: 15 times
Post by coop »
Did you find a solution to this?
I’m trying to replace Volvo part 1275711 3.0 bar Bosch fuel pressure regulator. I went to the junkyard and snagged another housing and unit.
Looks like I’ve found some stock in Europe and waiting on shipping quotes but doing some
But Bosch 0280160557 looks like a 3.0 bar unit and can be had for $20 so I’m looking twords that. I think I mistakenly read the t5s where at 3.8 bar and found one on a Mercedes at that pressure. So while at the junkyard pulled a few of those. They seem to fit in the volvo housing fine but I ordered new one at 3.8 bar which I’m now assuming is wrong and needed the unit off a Volkswagen
https://www.autohausaz.com/pn/0280160557
