How to remove this CEM connector?
tbaker644
Year and Model: 2011
Post by tbaker644 »
Upper righthand face of cem; there is one on the right side as well
Advice appreciated
tbaker644
Post by tbaker644 »
The answer for anyone who cares is '2 thin screwdrivers pushed in all the way, then push both outwards at the same time - left pivots left, right to right.
Whats left is a 1/16 x 1/2 x 1 inch white base , all of the black clip releases.
Its also possible to push too hard and break off the clip base, as I did on the 2d clip on the lower right.
2011 xc70 3.2
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Every modern car I've touched has its own bizarre idea of clips and clicks and tabs that break. Very few of them are obvious or intuitive. If I put a tool anywhere near one, I've broken it.
Has thanked: 1609 times
Been thanked: 4064 times
I struggle with all these. I do find the pushing the connectors together , eases the tension on the clips , and helps prevent breaksge
