I believe my tumbler is worn and needs replaced. Key spins and I have to "work" it to get it to engaged and start the car. I am looking to replace it. rather than ordering one from Volvo I am thinking about using the "antenna hack" to get around it. I will get a 2nd antenna, tape the key to it and tuck it under the dash.I would replace the key cylinder and just have 2 keys for the car, one for locks and one for ignition. here is my question:
Can the cylinder be removed from the collar, or does the whole collar need to be removed? I have seen some videos on removing the collar, but none on that remove the cylinder from the collar. If the cylinder can be removed from the collar is there a procedure or how to?
thanks
1999 S70 Key Cylinder
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 47 times
- Been thanked: 46 times
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- Has thanked: 1507 times
- Been thanked: 3824 times
Saw your PM, sorry, I’ve been on heavy travel.
You generally take the antenna collar off and tuck it under the dash withe the key taped up inside.
Getting the lock cylinder out is a lot more work, you have to Dremel the two security screws to release them, then replace the cylinder and steering wheel clamp. To release the lock tumbler you have to drill holes into the cast aluminum piece and squeeze an internal lock ring to pop it out.
Some details in Evitas maintenance record linked below
Link > Evita > page X > circa 2021 Fall
Found it
viewtopic.php?t=98078&start=50
Found it
- Grantkat
thank you!
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- 2282 Views
- 1896 Views
Last post by precopster
