Hey ! Just got another weird problem this morning.
My V70XC stalled this morning out of nowhere.
I thought it was the fuel system, i checked the fuel pump relay and took the fuel pressure from the front rail and everything's normal. After that i started it again, it started a few times but died instantly, after that i got under the hood to run tests to realise that the etm wasnt humming when engaging the key to accessory mode (it already has been remanufactured by XemodeX) so i replaced the main relay and the etm fuse, it works now but the ets light came up. Now it starts without any problem, but when i give gas it seems to do pops. Not sure where i should check next, looks like a sensor or electrical problem. (I already checked the MAF and it's not the problem) All the spark plugs and ignition coils has already been replaced.
What do y'all think?
Air problem
JelloBrick
- Year and Model: V70XC 2000
- Has thanked: 1 time
- Has thanked: 1853 times
- Been thanked: 1714 times
How cold is it there in Quebec, especially this morning? Was the car driving when it stalled or was it just started up and stalled before moving off?
JelloBrick
Not been worse than -12 and it was running, it stalled at a stop sign. I usually not have problems related to the cold.
- 471 Views
Last post by thedancingfiddle
- 1384 Views
Last post by Ozark Lee
