P2 PCV Replacement - Notes for the Uninitiated (from the recently initiated)
aewoodhouse
Year and Model: 2007 V70R
Been thanked: 7 times
Post by aewoodhouse »
Hi Everyone,
I just wanted to call out a few things I encountered during my first P2 PCV replacement. Things that delayed the process by days and challenged my sanity at times. Apologies for any redundance - I did read quite a few threads on the topic and used several youtube videos as reference so hopefully this will save someone the extra aggravation that I encountered. I get that experiences do vary, but some of these things I did not see mentioned in the context of the PCV install. I have done a wide range of repairs/upgrades on my Volvo's over the years including an intercooler swap which I tackled alone last year and this was by far the most tedious.
TLDR; I bought the basic FCP kit. Suggest also buying the upgraded PCV nipple (part number 30731007) pintle caps for the injectors (for Bosch type 3 injectors), a couple extra crush washers for the banjo bolt, screw type hose clamps and a magnetic pick up snake tool. For the impossible to reach manifold bolt, a 10mm crows foot on a 12" 1/4 extention worked for me (no swivel needed)
• I am a small in stature female with small hands. Spaces are so horribly tight that this was not a big advantage. Do yourself a favor and remove the large coolant hose to the thermostat and the air filer box for more room.
• The FCP tutorial video on this job mentions replacing the very brittle PCV nipple (more like a straw) with the upgraded version used on the s80 and xc90 (part number 30731007) I'm here to tell you, just buy this part! The chance that this piece of brittle plastic garbage will break during disassembly is high. In my case, not a single dealer had one in stock so the job was stalled by three extra days while I waited for one by mail. (Looking at you FCP - please call this out on your P2 PCV kit product pages if you're going to mention it in the video!)
• Two of the five pintle caps (the little plastic disks that hold the o-rings on the ends of the injectors) broke when I removed my fuel rail. More old brittle plastic. Buy some of these in advance too! They're about 50 cents each or less. This surprise also involved waiting for mail delivery. There are plenty of people out there who encounter the same thing and just reinstall the rail without these caps but when it involves fuel, I'd rather do the job right.
• Regarding the infamous impossible far left manifold bolt: I was able to access it with a 12" long 1/4 socket extension and a 10mm crows foot. No need for a swivel. I realize that it may be rotated ever so slightly beyond the accessible range of the crows foot, in which case the swivel might provide that last bit of needed range but worth trying to get at it without one first IMO.
• The banjo bolt - Oh the banjo bolt. This thing is located on the bottom side of the manifold at a really oddball angle and used to connect the new PCV nipple to the manifold. Problem is, that because the new S80 nipple straw is longer than the original, the parts don't line up quite right so you have to bend the nipple assembly while simultaneously trying to thread the banjo bolt that attaches it to the manifold at an unintuitive angle WITH two copper crush washers. And you have to do this by feel alone. For me, this was worse than the aforementioned manifold bolt as I dropped the crush washers into the engine bay at least half a dozen times and couldn't rely on my magnetic pickup tool to retrieve them. At one point, I wasted more time going to 5 different auto parts stores looking for more washers, but none to be found that were the right size. I ended up finding the ones I'd dropped with a very bright head lamp. I'd suggest buying spare washers. Here again, very little added expense to save a lot of potential aggravation.
Anyway,
To finally get the banjo bolt threaded, I ended up going against all guidance, disconnected both the hose and the other end of the nipple from the PCV box and threading it to the manifold while it was still removed thus allowing a little more room to move. With the new hose clamps in place on the hose and PCV, getting the other end of the nipple and accompanying hose attached to the PCV was tight but doable. NOTE: This is not the prescribed order of reassembly but it worked for me.
• Somewhere it was suggested that the two T30 torx bolts for the thermostat housing be replaced for hex bolts while they're accessible - making future access to thermostat easier AND immediate access to the impossible 10mm manifold bolt much easier. The thing is, the bottom one is barely accessible without removing the power steering pump. These torx heads were fast to strip especially due to the slightly imperfect angle on the bottom one and I ended up having to unbolt the PS pump anyway (requires removal of the serpentine belt) If I had it to do over, I'd just unbolt the PS pump instead of trying endless variations of tools to get a good hold on the bolt in a nearly impossible to reach location. The stripped bottom bolt turned this into a secondary ordeal that I ended up addressing it after installing the new PCV - thus not benefitting from the extra clearance it allows to the impossible manifold bolt.
• Finally, I will add that the FCP kit comes with the same single use pinch hose clamps that the car was originally equipped with. However, I would highly recommend using the more common screw on clamps as the potential for having to retrace some steps is high if you've never done this job.
• A final postscript: I installed the FCP silicone pipe kit when I did the intercooler last summer. They had since gotten oily. I suggest cleaning the oil off the inner connection surfaces VERY thoroughly or risk the pipe just slipping right off the connection no matter how tight the clamp.
Both the throttle body pipe and boost pipe came undone on me at separate times after reassembly. I suspect this would be less of an issue with the OEM pipes but figured it was worth a mention because you REALLY don't want to have to get back at the throttle body pipe after surviving all of the above.
Cheers and good luck!!
2007 V70R
2004 XC70
Past:
2009 C30
1998 S70 - Turquoise 5 speed
2000 XC70
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Yes. The PCV project can be a frustrating bear. It can take you the tricks you can muster to complete.
When I need to grab non steel parts out of reach, I have two tricks - a push button grab tool on a stick and a ball of tape with sticky on the outside on a stick.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
great job, I haven't done mine yet but was told the hose to the banjo bolt is slightly too long so its a lot easier to connect the banjo bolt first and then connect the other end, sounds like you figgered that out yourself.
In anticipation I bought the recommended 10mm low profile swivel socket, 1/4in drive. Telton makes it. $12
https://www.amazon.com/TEKTON-Drive-Uni ... r=8-6&th=1
Has thanked: 1609 times
Been thanked: 4065 times
Well done that woman!!
My trick with the banjo is secure the washers with a sacrificial o-ring, once you get the threads started you grab the oring with a pick and break it off. I also buy lots of washers.
Good note on the 1/4 inch drive 10mm socket for the IM bolts - I reach for that right away on both P80 and P2
Banjo first and then PCV hose seems to be the easy street path here, agreed.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Good write up. Reinforces that some of the best money I spent was the $400 for my Indy mechanic to do my PCV.
:P
My fear was doing it wrong and having to start over. I’ll stick to suspension and brakes for DIY.
08 C702.5T (sold)
The non-Swedes:
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Post by mtd240 »
Just did this job on my 07. Nice list of pointers - really wish I had a set of crows feet. I ended up squeezing my hand behind the intake with a long 10mm combo wrench and turning it bit by bit.
Also broke 3/5 injector pintle caps. Just installed them as is, will get new injectors soon anyway (180k miles seems like a good life 😅).
Used all Gates parts (apparently OE supplier? We’ll see how it holds up) - that got the cost down so that it wasn’t totally ridiculous to just buy the whole hose assembly (30731068) instead of just the notorious nozzle/nipple.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
All very wise words and exactly the same troubles I experienced. Right down to the pintle caps.
Only suggestion and tool that really helped me this job was a small maybe 4” box wrench 17mm to get that banjo bolt out. Job probably took me 4 hours and was lucky enough my local Carquest had a nice copper washer kit that had the 12x16 size.
Everyone reading this please please just take the 5 minutes to remove the damn PS Pump and thermostat and forget the threads where everyone spends 5 hours trying to avoid it.
04s60 2.4
04xc70 2.5t
