Parameters of the tapping screw of engine undertray (1997 V70)
Quixy
Year and Model: 1997 V70
Post by Quixy »
Hello!
So I have a question about V70 P80 engine protection plate mounting screws. I just bought the plate, but just got information that there are no tapping screws on the warehouse and I should wait for about 20 days to get these 5 mounting screws to here Estonia. These seem to be some special inner-torx headed tapping screws to me.
So my exact question is if someone could tell me the exact dimensions of these screws so I could buy them from a local hardware shop.
As I know so far, the OE-code of the screw is 986122. The exact length should be 13 mm and thread size 6,3 mm as I read from skandix.de. But I can't figure out or find information from anyhere about the diameter of screw's thread like is it a M6 screw, M4 screw or which? Or maybe can someone tell the size/diameter of the hole where this screw sits in.
May someone more familiar with these P80 Volvos help with that please? I just need the correct parameters of the screw to buy them from local hardware market.
I attached some photos with so that it would be easier to understand what I mean ;)
Has thanked: 2203 times
Been thanked: 1852 times
The information is on Skandix website. 13mm long, 6.3mm diameter inner torque screw.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
The two holes marked with blue arrows bolt into the tabs which are already on the subframe. Just get two short bolts that fit the threads.
The three holes marked with red arrows need to be drilled into the subframe
I used three self tapping hex bolts similar to this. They were around ½" long
I later removed the self tapping hex bolts and fitted Rivnuts with bolts the same size as the other bolts
Rivet nuts.jpg (144.36 KiB) Viewed 1631 times
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
I like the Rivnut solution with bolts better than the self threading bolts. Are there no mounts at the back of te unit or does it tuck in somewhere so not needing bolts?
P80GLT
Post by P80GLT »
It tucks into the rear of the subframe
2010 XC90 SE...SOLD
2005 V70 2.5T SE
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
scot850 wrote: 02 Apr 2025, 19:13 The information is on Skandix website. 13mm long, 6.3mm diameter inner torque screw.
6.3 diameter? That's a thing? Is it actually a 1/4 inch bolt?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Likely. SAE on a Volvo post 1990's?
