Hey folks,
My 2005 p26 d5 185hp has the following problem:
Running d5t5 215hp no egr, no dpf for a year. Everything is running fine. Last week I had to visit tüv (German gov inspection). It passed the exhaust test but it was in limp mode. ECM complaint about dpf differential pressure which should be deleted since I flashed the software last year. I flashed again to 185 hp, no egr, no dpf. Dtc is gone, but still no power.
Any ideas? I replaced the boost pressure / temp sensor. Nothing changed. When I check life values on Vdash all the values do not seem plausible but the graphs do. For example boost temp is going up and down when using a heat gun to the sensor. But the value is changing just from 121 to 122. Is it possible that vdash converts the values with a wrong factor? Same with DPD pressure. Reading is somewhere at 50000 hpa.
Thanks in advance!
Julius
no power, no DTC
- Has thanked: 2656 times
- Been thanked: 1248 times
Welcome to MVS, Julius. Do you have codes? We're not a very diesel-centric forum here because we got 0 Volvo diesels in North America after the 240 diesel. But I'll try to help
- 307 Views
Last post by stephansvolvo
- 1476 Views
Last post by thepetercasey
