I've got a 2013 D4 V70. The air con compressor clutch is much harder to access than on the older mk 2 model I had before.
Now I've finally reached it the springs are different - not the round cloverleaf type but straight ones.
Can you still do the cable tie fix ? and where do you put the ties please?
aircon fix with cable ties on newer models
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
On the cloverleaf type you’d put the zip tie under it to add some tension to the clutch—but without too much to drag when not engaged.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 13 Replies
- 3587 Views
Last post by amblerman
- 2299 Views
Last post by supebeal01
- 775 Views
Last post by marron4655
- 1897 Views
Last post by A75stevie
- 1361 Views
Last post by lummert
