Valvoline Restore and Protect In Volvo
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I've considered it, but I normally run 5w40, and wasn't sure a 5w30 would be a good idea.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- MoVolvos
.454cid wrote: 08 Aug 2025, 23:10 I've considered it, but I normally run 5w40, and wasn't sure a 5w30 would be a good idea.
I also run 5W40, Rotella T6 being the one most used then Castrol Edge Titanium. Have been experimenting with 15W40 Rotella T6 in 3 cars for winter and summer and so far all okay.
The 5W30 should be fine for one or two changes unless you really exercise and glow the turbo, it shouldn't break down between a 3K to 5K change interval. I would change the filter out at 1K or 1.5K miles in case you have lots of deposits but not carbon build up / coking which requires several changes.
- MoVolvos
I do experiment with other oils when there is a good sale and so far all have been okay. The goal is to stay with a 6 month or 5K max interval. Don't care for Liqui-Moly in any weight and have used mostly 5W40. Though not a bad oil just not worth the cost and seen to poop out quicker than the Rotella T6 and Castrol Titanium.
- 643 Views
Last post by foggydogg
- 4076 Views
Last post by timmybdaddyof3
- 2357 Views
Last post by huzzsaba
- 6169 Views
Last post by jimmy57
- 2294 Views
