I just performed a trans flush on my '98 S70T5 and I used Valvoline Dex/Merc trans fluid. My question is not with the flush procedure but with the use of Valvoline Dex/Merc fluid. It states on the bottle that it is for transmissions requiring Dextron-III/Mercon but the color just doesn't seem right. It is more of a light red and is not as deep red as I am accustomed to seeing and it also seems to be thinner than usual.
To try and figure out if it was just me, I did a side-by-side comparison with a bottle of Formula Shell and also a bottle of Pennzoil I had on the shelf and to me it certainly does not appear to be the same color or viscosity. Should this be something that I should be concerned with or is it just that I am not familiar with it? Or did I just get a bad batch of fluid and need to start over?
Thanks,
Tom
Valvoline Dex/Merc for Trans Flush
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
One man's opinion: if it doesn't look right drain it and redo the job. I worked for a global oil company for years and we regularily had batches of oils that weren't up to spec. I didn't care if my motor oil was somewhere in bewtween 0w-30 and 5w-30 and not quite 0w-30, but slightly off on atf could cause trouble.
In your case i wouldn't worry about the color too much, but if the viscosity and general appearance seem totally different rather redo the job
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- charleskennedy23
- Year and Model: 1998 V70 T5
I use this stuff... I documented my last drain and fill here...
https://www.matthewsvolvosite.com/forums ... 08#p414808
Some good discussion there as well as a pic of the fresh valvoline fluid next to the stuff I drained. While the drained fluid looks pretty brown, the fluid on the dip stick was bright red.
Charles Kennedy
"HAGRID": Black '98 Volvo V70 T5
- Clemens
is the Shell one brand new? This is quite a difference. It might be color additives though.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- tom39
- Year and Model: 2011 S80
Yes, both fluids are new. I have an email into Valvoline about the color and viscosity difference but I have not gotten a straight answer from them yet.
I did however do some research on the color and viscosity of trans fluid last night. The info I got back about the color is that it is red dye is that it is added to the oil to make it more distinct and set it apart from other oils. I also found that the viscosity index of the Shell fluid is 177 and the Valvoline is 174 and that the Valvoline has a greater change in viscosity with changes in temp than the Shell oil. This may account for the appearance of a thicker oil out of the jug but I am not a chemist and really have no real way of knowing. Anyway, my guess is that Valvoline uses less dye and their viscosity is less but within the set requirements for Dexron-III. Again, I am not an expert but I am hoping that it what is happening here.
11 - S80 Silver 132k/mi
- tom39
Are you saying "Redder is Better"?jimmy57 wrote:The actual hue of the red coloring in ATF holds an importance similar to marking EXACTLY within the lines on an optically read test score form.
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
i use the valvoline dex/merc (as recommended by parts store/indicated on bottle) with no issues. flushed my trans when replacing the seals last month, have been running valvoline dex/merc for about 2000miles, no issues or changes in trans behaviour since seal replacement/flush.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
jimmy57
- Been thanked: 322 times
No, I'm saying that crap fluid with lush red coloring is not as good as faded red high quality base stock, lower but more stable viscosity fluid.
Some of the brands with unquestioned quality that I have bought had odd colors for their power steering fluid, ATF, and motor oil. I am not so sure that the ISO standard for lubricant color has strict controls of the tint of the various colors.
- 3650 Views
- 2366 Views
Last post by huzzsaba
- 14 Replies
- 2346 Views
Last post by ThommyKent
- 6180 Views
Last post by jimmy57
- 2354 Views
Last post by oragex
