Starter Motor 2009 XC90
rp2005
Year and Model: 2009
Been thanked: 3 times
Post by rp2005 »
Volvo dealer is saying my starter motor has failed and they want $1300 to replace. Why is it so much? I can get a new starter on Rock auto for $77-$130 and I found this video that makes it look pretty straight forward. Anything to watch out for?
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 155 times
Been thanked: 141 times
Post by Vova585 »
Depends on your engine labor time can be different. Volvo dealer will use oem or oem remanufactured starter unit. Lets imagine the price of the starter from dealer is 500-650 plus 2-3 hours of labor(at about $200 per hour) and you are close to the quoted price.
Buy your parts from FCP euro and have lifetime warranty. If possible buy new and not remanufactured unit. If you are doing it by yourself you will save a lot of money, so better buy quality parts.
P.S. Always start with disconnecting your car battery.
rp2005
Post by rp2005 »
Thanks! I had it towed to my house and am going to tackle it myself.
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 184 times
Post by pgill »
You should watch this video
The video that you posted is not for the 3.2L
Good luck
Paul
Capndirk
Year and Model: 2009 XC90
Has thanked: 7 times
Been thanked: 11 times
Post by Capndirk »
Be sure to disconnect the battery prior to working on the starter positive cable. Also inspect the starter cable terminal end to be sure the insulation is intact and cannot come into contact with the solenoid case where the cable and terminal bend around it. There should be a rubber boot that will cover the the positive terminal on the starter terminal.
