Coolant Leak (2004 V70)
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
BobbyC777
Year and Model: V70 2.5T, 2004
Has thanked: 15 times
Been thanked: 5 times
Post by BobbyC777 »
Apologies but I saw hundreds of posts for "coolant leak" and I did not look at them all.
I am starting to lose a little coolant - need to top off reservoir once a month or so. I feared head gasket & then noticed some on garage floor. I am attempting to post a picture - taken from underneath the car looking up. The picture shows a plastic vent tube of some sort that has traces of coolant running down it. What is this tube?
The water pump is not visible as it's behind the timing cover. But if it is leaking (weep hole) does it get flung out by reciprocating parts or just drip in one spot?
Thanks for any tips. I am 10K miles away from a timing belt (due at 240K) so I may try to live with it until then or if it gets bad just accelerate that service.
Bob (North Carolina)
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
vtl once said the nipple on the coolant reservoir cracks. It could even be the cap(always by original never aftermarket trust me on this).
BobbyC777
Post by BobbyC777 »
Thx - that would be nice if it was the reservoir. BTW I have never been able to release the tab that connects the coolant reservoir to the power steering reservoir. I have tried and tried!
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
BobbyC777 wrote: 16 Sep 2025, 07:06 Thx - that would be nice if it was the reservoir. BTW I have never been able to release the tab that connects the coolant reservoir to the power steering reservoir. I have tried and tried!
flat screwdriver blade, they usually snap off anyway, even my new one broke.
BobbyC777
Post by BobbyC777 »
Thanks. I have seen some videos where it just pops right off and others where both coolant & power steering reservoirs got taken out together as they could not separate them while in place.
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
At this 240K mileage...
- WP
- Reservoir and its small hose.
- Thermostat gasket and the small hose (I posted some tricks in this forum).
- Radiator itself.
BobbyC777
Post by BobbyC777 »
Good tips! What is this plastic vent assembly in my picture? Thanks!
br0dy519
Year and Model: 2004 XC70
Has thanked: 123 times
Been thanked: 115 times
Post by br0dy519 »
Isn't that the water drain for the cowel?
04s60 2.4
04xc70 2.5t
BobbyC777
Post by BobbyC777 »
br0dy519 wrote: 16 Sep 2025, 10:08 Isn't that the water drain for the cowel?
I'm going to go out and turn the hose on right now - thanks!
UPDATE
I just put the hose in each of the 2 cowl drains. Both of them appeared to drain maybe 3 feet aft of what we were thinking was the cowl drain tube exit. Nothing came out of it. I appreciate the suggestion - I thought that was going to be it!
Has thanked: 1498 times
Been thanked: 3810 times
That’s the famous P2 viper.
It’s a down draft tube for the ECU box I believe
viewtopic.php?t=89322&hilit=Mystery+tube
