2006 XC70 2 calipers will not bleed Topic is solved
FarmallM51
Year and Model: 2001 S60
Been thanked: 5 times
Post by FarmallM51 »
LR & LF calipers will not bleed even with 15psi pressure on reservoir. The other 2 bleed fine. I removed the bleeder screws and cleaned the orifice in the caliper. Brakes work great & no additional wear on rotors or pads. Can I increase pressure above 15 psi or add pressure by depressing brake pedal?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- Do not increase the pressure, the reservoir may blow up.
- Get a 2nd helper to do it the old-school way (pressing the brake pedal) without pressure.
FarmallM51
Solved. I closed all the bleeders and released the pressure on the reservoir, started the car, and applied the brake a couple of times. Re-pressurized the reservoir and the caliper bled ok.
Has thanked: 2199 times
Been thanked: 1851 times
Had a similar issue recently. A young guy I help with his V50 T5 AWD had fitted a new (rebuilt) caliper but could not get any fluid out it no matter what he did. We tried using a pressure bleeder and bled the whole system but even with a new hose, it still would not bleed. I disconnected the flexi, removed the bleed screw and nothing would come out of it even with 90 psi of air.
He got another rebuilt caliper from the supplier but bought a Nugeon which is my go-to reman brand. This weekend he was back with fluid leaking. These cars have hydraulic parking brakes operated by a cable. It was leaking around the parking brake spindle!
Bleeding these systems can be a challenge. I have yet to try see if Vida will bleed the system or even the ABS unit.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
scot850 wrote: 16 Apr 2026, 19:49 Had a similar issue recently. A young guy I help with his V50 T5 AWD had fitted a new (rebuilt) caliper but could not get any fluid out it no matter what he did. We tried using a pressure bleeder and bled the whole system but even with a new hose, it still would not bleed. I disconnected the flexi, removed the bleed screw and nothing would come out of it even with 90 psi of air.
Never had this problem. I have a Motiv pressure bleeder, but years ago switched to another Motiv, a vacuum pistol-type that bleeds by sucking fluid from bleeder screw.
VIDA of course helps with air trapped in ABS.
FarmallM51
What's the process for using VIDA while bleeding?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I've got to ask about your user name. Do you have a Farmall M tractor? See my signature including Farmall 400 Diesel. This is basically a Farmall MTA with styling update.
Has thanked: 1609 times
Been thanked: 4065 times
I’m pretty sure everyone in a Iowa has a Farmall for harvesting potatoes. In their spare time they perform research on maize biology.
FarmallM51
1951 Farmall M, gas, tire chains & 3-point hitch with 8' blade for clearing snow. Added electronic ignition and block heater for cold weather starting. Few potatoes here but the Iowa State Ag department does a lot of maize research.
FarmallM51 wrote: 19 Apr 2026, 04:34 1951 Farmall M, gas, tire chains & 3-point hitch with 8' blade for clearing snow. Added electronic ignition and block heater for cold weather starting. Few potatoes here but the Iowa State Ag department does a lot of maize research.
You got to watch Abscate when he talks about agriculture. He has typical NYC knowledge of agriculture.
But he does tell good Dad Jokes.
You have well optioned M.
