I was coming here to ask opinions on what might be happening with my 2006 xc70, and I think I stumbled on the answer, but I'll ask anyhow.
I've recently had a cracked radiator replaced, and also had the timing belt replaced a few months back. Since the timing belt was replaced, I've felt a sort of rumble or vibration while in gear with the brake depressed, like at a red light. It kind of sounds like a washer if the load is unbalanced. Any suggestions on what to look for to determine the issue?
Uneven cycling in drive with brake depressed
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Sorry, but there can be many explanation for your symptoms. You are basically putting the engine under small load with putting it in gear. In order to tell anything next, one need to have access to the good scanner tool. I would look if you have any pending or active codes(you would probably report check engine here). If no codes, then you have to look at long and short term fuel trims to get an idea is it due to lean or rich condition(most likely lean) and then work from there. Dont throw parts at it and better diagnose exactly what is wrong since you can put plenty of parts and get nowhere.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
What if you use the parking brake to keep the car from rolling? I’m thinking that if it’s only when you are holding the brake pedal down then maybe you have a leaking brake booster or the associated vacuum hose.
Do you get the same feeling roughness when in reverse and holding the brake?
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Definitely engine mount, or a coil starting to go bad and small misfire.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 2655 Views
Last post by DraftyBread
- 13 Replies
- 4055 Views
Last post by WhatAmIDoing
- 1772 Views
Last post by Shanestrait
- 16 Replies
- 1271 Views
Last post by br0dy519
- 659 Views
