Correct tires... 2019 S60 235/45R18 98W
fields 100
Year and Model: s 60 T-5 2013
Post by fields 100 »
Hi all,
Have 2019 s60 Momentum and in need of the 2 front tires. The factory tires are Contis 235/45R18 98H. Have a quote for Bridgestone Prestige Turanza for $200 less than the Contis.The only difference is that they are 98W, rated for much higher top speed. I've heard that the higher speed rating the stiffer the side walls are.They are causing albeit sportier but at the same time tougher ride. Would it be correct assumption or for the regular driver which I am there should no noticeable difference? Thanks.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
I think that if you think you can notice the difference, then you are noticing a difference and it’s real.
Inflate (deflate) them to the low end of the range to try to improve the ride.
Also -> Amazon link
