S80 remtote fob sluggish opening doors
morais
Year and Model: 2012
Post by morais »
ola, tenho um S80 D3 de 2012, e estou com problemas no comando de chave, mesmo com uma bateria nova, o comando tem muita dificuldade em abrir portas, mesmo junto ao carro tenho que estar muitos segundos a pressionar comando de abertura para porta abrirem, podem ajudar com dicas ???
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
Welcome to MVS, morais. Please use English. Translated:
hi, I have a 2012 S80 D3, and I'm having problems in the key command, even with a new battery, the command has a lot of difficulty opening doors, even next to the car I have to be many seconds pressing opening command to open door, can help with tips ???
Also -> Amazon link
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
1. Any chance you have 2 key fobs? Is the issue reproducible with both fobs(is available)? If the issue is reproducible with both fobs- key fobs are not the issue. If you only have 1 fob- any chance your local parts stores have keyfob tester(it is a sensor that you put your keyfob next to and press any button. It will show you the signal strength which usually is indicative of battery health. In your case keyfob battery is new, so it will show you if the fob is capable of strong signal. ). This device can be alternative purchased on ebay for about $20 and can show you accurate frequency reading , etc.
2. When this issue started or you bought this car like that?
3. Any chance you are seeing fluid leak like picture in your rearview mirror?
