1995 Fuel hoses lines size Topic is solved
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
Hy Guys,
I've replaced the all fuel lines last winter. Unfortunaltly, hoses seems to be as bad quality. I need to rebuild the all thing.
Which size of hose shall i use for inside :
  • A mm and outside B mm ?
Manov
fuel hose.jpg (79.41 KiB) Viewed 444 times
Olegs855R
Year and Model: 1995 855 Turbo “R”
Has thanked: 6 times
Been thanked: 23 times
Post by Olegs855R »
manovlov wrote: 28 Aug 2026, 21:23 Hy Guys,
Manov
Make sure it is rated for fuel injection
Olegs855R
Post by Olegs855R »
Manov
I’m pretty sure 6mm is the common FUEL LINE ID and if not, it shouldn’t be larger than 8mm ID YOU WONT NEED ANYTHING LARGER THAN THAT unless you’re driving around a car with 1000cc injectors and a thirst motor.
manovlov
Post by manovlov »
It will be 7 mm X 13 mm, so. Thanks.
