Will try this later
1999 s70 stuck key in ignition , Betty White
- Has thanked: 1613 times
- Been thanked: 4078 times
- Has thanked: 2215 times
- Been thanked: 1853 times
If that over-ride button gets stuck, good luck getting it out using WD-40 and keeping it working. Pulling the console to access the button fully and then cleaning it fully will have it running good again. You could consider a smidge of silicon oil after cleaning it to re-hydrate the button slider. Broken button is a common issue. Replacement is about $15 from FCP. With practice a 10 minute or less repair.
Good Luck!
Good Luck!
- 23 Views
- 21 Replies
- 2901 Views
Last post by sleddriver
- 4194 Views
Last post by rfm77555
- 2481 Views
Last post by michelleives
- 4278 Views
