same old 1982 240 dl, still working out this car
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
sergitin32
Year and Model: 1989 240 DL , 1995 9
Been thanked: 3 times
Post by sergitin32 »
oki for those not reading the previous postes, this is a 1982, 240 DL, canadian engine, meaning B21A engine, single carburator, the simplest engine ever... not fuel injection non turbo, just the old school 4 times, contact breaker old iginition system... totally old school easy going on some hands to get into doing all the mechanical work with regular tools.
So for making the short, i just did the whole valve job to the car... change the valve seals and every gasket... put back every bolt ans cable back... made some mistalke already explained on the old postes... loo for the 2same user in the forum, old stuffs.
So after this i've been looking clearance in between the shaft and the valves, changing shims like 3 times now, locking more and more all the bolts, with the torque wrench... still the car sounds not good, really loud, like the whole engine hitting inside...
my few thoughts, are:
1-still not enough clearance... since i am still like 0.012-0.013 inches... will go to 0.014-0.015 later.
2-missing some timing experience to hear the right sound?
3-i f****d the shaft on the disambling and ensambling trials?
As for the future i will change all the electric engine stuff, spark plugs, cables, rotor, and will try doing some oil change and fuel filters... too see where this drives me...
I wont forget to mention i also did my self the whole engine harness, cable by cable... and i think this been brand new would take a big worry from my mind... since al cables were pealed... crazy, called volvo dissease i now understand what it means.
my main concern would be... I want to know if there is a name for the tool that extract the shims of the drums... i need to order one of those since the two times before was hell to get those out, and this time i want to make it right just to save time and exford... need one tool that extract the shims off the drums that adjust up on the engine valves... just below the shaft... need to change them in order to look for more clearance... i already have the prine bar.. just need the one that some how adjust to the shim and pulls it out in one second!!!! jesus its been like 15 minutes per shim of my life strugglig that tinny screw driver... and i wont pay that price again, prefear to pay for the tool price!!! thanx very much. :)
thanx alot for the time... will keep posting on whats going on with this.
sergitin
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Good to hear from you again, unfortunate that you are still having problems.
The tool you require is a Valve Tool (Depresses Followers To Allow Removal And Installation Of Shims). The description came from FCPgroton who want $60.00 for one. You may be able to find something similar, but cheaper, in a parts store where you live. You may even be able to hire one.
Good luck.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
sergitin32
I already got a prine rool to depress the drums, and the shims are free, but they are as well pressured into the drums, cuz these have like taller edges to grap the shims of course... and the shims enter there under preasure filling like a groove in the inside of this edge... so i need to find something that grabs them (shims) like a pinch surounding the shatf from above... i still dont know the name, have seen some like that in haynes but i cant find any anywhere...
really need to change shims again so i know if the noice comes from lacking clearance...
thanx anyway bill... and if I am wrong please correct me...
have a nice day!!!
sergitin.
