Runs like a champ when it is cold!! Under load, after the engine is fully warmed up, 15+ miles on freeway, the engine stumbles and misses upon acceleration. The codes set are P0302 and P0202. I have been working on this for a while. The P0202 code is new as of this weekend, before was only P0302. I have been advised by indy Volvo guy to do all below. Other advice has been to fully warm-up the car and then pull the connector from each sensor while running and put them back on. The sensor that does not change how the car runs is the suspect one. Have not tried this yet. The following have been replaced:
Plugs: used Bosch FR7DC
Wires: Bougicord from IPD
Cap and Rotor: Bosch
Ran 1 bottle each Lucas injector cleaner and Redline cleaner through for 200+ miles. Change oil and filter to Mobil clean 5000 about 400+ miles ago.
Next step is to check compression in cyl #2, will do tonight.
Any other suggestions??? I am getting worn out by this one.
Thanks.
Poor acceleration/stumbling 1997, 850, T-5
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Sometime it is just the injector electric plug gets fouled up and needs a little cleaning. Also check the wires for chafing. The plastic shielding on the injector wires leaves a lot to be desired,
If the injector is truly dirty, injector cleaner in a bottle will not work. It is #2 injector.
Klaus
Klaus
Klaus
- 526 Views
Last post by Alan99
- 4606 Views
Last post by freewalk
- 17 Replies
- 1858 Views
Last post by subzerocarfanatic
- 18 Replies
- 9457 Views
Last post by nucci480
- 1959 Views
Last post by warmblood58
