CAR: 1997 850 GLT Wagon - 75000 miles
PROBLEM:
Air pump sounded like a fork stuck in garbage disposal at every cold
start, is now not running at all. Check engine light is on.
QUESTIONS:
1. Is there any way to permanently disconnect or disable air pump
without triggering check engine codes or other engine or ECU problems?
I live in warm climate (Los Angeles) so air pump does very little good
and repair is $$$.
2. Is it true that "fuel trim" is disabled when check engine light is
on? What happens if you keep driving like this?
850 Air Pump ñ Check Engine Light Topic is solved
nightshift
- Year and Model:
You will probably get a lower mpg with the fuel trim adjusted. I would try and maybe find a used pump to save a few bucks. Since everything is dependent on another component, as far as info going to the ecu, it would be easier just to replace the pump.
I would do a search on the net and see what used parts you can find, since there are some good deals out there, even try ebay motors.
- 1754 Views
Last post by erikv11
- 6325 Views
- 2765 Views
Last post by Georgeandkira
- 2927 Views
Last post by JLGParis
- 2586 Views
Last post by theWIFES_S70
