1997 850 Growling noise
I'm getting a growling sound on the front R side behind the headlight. It happens when the ignition switch is turned on and the engine is off. It continues when the engine is running? Any ideas what it is? It almost sounds like a bad bearing noise.
phoenix_iii
- Year and Model:
Really get your ear, tube, or stethescope on it and tell us where it is coming from. If it's ignition only, it may be electrical...
Welcome to the site
Welcome to the site
1995 Volvo 850 Turbo
- Year and Model: Many Volvos
- Been thanked: 76 times
It is likely the secondary air pump getting ready to croak on you. Does the sound quit after a few minutes?
If it is the pump you will need to replace it and the valve or it will just kill the new pump.
This might save you some money.
https://www.matthewsvolvosite.com/air_pu ... nt_850.php
- Has thanked: 17 times
- Been thanked: 35 times
Right...I'm thinking fan bearing on the large fan that cools the radiator and engine.
You hear it with the Ignition ON and the Engine OFF....the ventilation fan would come on.....probably a noisy bearing in the vent fan motortht828 wrote:I'm getting a growling sound on the front R side behind the headlight. It happens when the ignition switch is turned on and the engine is off. It continues when the engine is running? Any ideas what it is? It almost sounds like a bad bearing noise.![]()
Just a thought!
Cheers
1997 850
2007 S40
1998 E300 TD
1969 Austin Mini
2007 S40
1998 E300 TD
1969 Austin Mini
Thanks for the responses. I have replaced the secondary air pump and valve about 10K ago. At first I thought it had gone bad again, but on inspection its good. Also wrong side as mentioned, but I double checked to be sure it wasn't coming from the pump ( sounded similar). Any other components on the RH side?
Using the stethescope, it doesn't seem to come from the fan motor, but is loudest on the RH lighthousing. I'll try unplugging the fan to see if its referred noise.
There is an atmospheric pressure sensor that is triangular in shape that is mounted to the right inside fender between the light housing and the windshield fluid tank. Just on a whim, check it out to see if it's not the culprit.
My bad,Also wrong side as mentioned
I looked out the front window of the house and - looking at the nose of the car - it was indeed the right hand side. I think I'm going to start saying "Port" or "Starboard".
On the (USof A) passengers side you have many options. Alternator, A/C compressor, and the serpentine belt tensioner or idler come to mind. We don't like to think of the other things that lurk behind the plastic cover.
Thanks Ozark Lee
Luckily, I doubt it's any of the costly items you mentioned. I get the noise all the time the key is in the on position, even when the engine isn't running. I'll check out the atmospheric pressure sensor in the morning,
