Had an earlier post about repairing driver's side seatbelt.
It is now done. Found the replacement from MySwedishParts.com for about 2/3 price of dealer. Not a difficult job, even for someone like me with minimal mechanical talent.
SRS light remains on from when i disconnected the original belt apparatus. I guess this needs to be reset at the dealer/mechanic who can check relevant codes, etc.?
1995 850 trubo wgn seatbelt
- Has thanked: 17 times
- Been thanked: 35 times
Yes, dealer only to reset the SRS....to bad you didn't disconnect the battery before you took the old one out...this would have avoided this.
THe battery was disconnected for at least 20 minutes before I took out the old. Tried to get the tensioner to release before I bought new one. Had to drive without it for a few days then disconnected it for twenty min before I put in the new one[/u]
jks1259
Well, you had to do what you had to do. Once the light gets set, it's a dealer issue. No amount of disconnecting the battery will turn it off.
karageorge2
- Year and Model:
when i replaced tb water pump etc my battery was disconnected for a few days. when i reconnected and cleared all codes including an srs seatbelt sensor code that had been plaguing me for 2 years it went out! finally! thank god iwas so tired of seeing that red light. and it has stayed off.
Not sure why but it is OFF!
- 11 Replies
- 2429 Views
Last post by volvolugnut
- 1347 Views
Last post by norbert
- 1317 Views
- 1030 Views
- 1552 Views
Last post by osman
