1995 850 GLT Drivers Side Seatbelt Replacement
busheygirl
- Year and Model: 1995 850 GLT
My driver's side seat belt failed, and I currently have the passengers side seat belt installed as a quick fix, but I will need to find a replacement seat belt soon so all of my passengers don't have to sit in the back. If anyone has any leads on where to find a replacement seat belt (aside from ebay) I'd appreciate a link to a website or some place. I'm okay with a non OEM part or universal fit seat belt as long as it fits and works properly. I'm not interested in drilling new anchor holes, but if it comes to that, I'd do it.
- osman
- Year and Model: 2002 c70 hardtop
I go to my nearby junkyard.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
- Year and Model: Many Volvos
- Been thanked: 76 times
There is actually quite a bit going on with the seat belt since it ties into the SRS. You need to remove a battery cable before you start unplugging things or it will set a SRS error code and disable the system. If the radio is factory you will need to have the radio code to get it working again after the battery gets hooked back up.
Osman has the plan, just grab one at a pick-n-pull but make sure it spools out before you even remove it. They tend to get stuck as they age and the grease on the pawls dries out. I bought a new one for one of the cars but it was painfully expensive as I recall. Any 850 seat belt will work but the 70 series belts are different at the point where they anchor to the seat.
- osman
Yes, they are different however I just used a bolt and washer to make an s70 belt fit on an 850 seat or vice versa. I think I was putting S70 seats in an 850.
Brick Life
99 XC70 AWD LPT 115
99 XC70 AWD LPT 115
- 495 Views
Last post by wheelsup
- 1103 Views
Last post by Klausc
- 979 Views
Last post by odaikorob
- 552 Views
Last post by adrianleon0912
- 644 Views
Last post by basilhenriques
