braking pulse.
- Year and Model: Many Volvos
- Been thanked: 76 times
If the pulsing is very fast then it is the ABS. If it is a slower pulse that corresponds to each revolution of the tires then you have warped brake rotors.
JRL
- Year and Model: Several
- Been thanked: 16 times
You need new rotors
chuckcintron
- Year and Model:
Besides rotors, anything that introduces play in the suspension can contribute to this. I had perfectly fine rotors, but had a nasty pulsation due to a broken spring seat.
Any of that stuff at the top side of the strut, as well as a (badly) worn wheel bearing can introduce a pulsation when braking.
-Chuck
-Chuck
1997 855GLT
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
Also realize that if the ABS sensor loads up with metal filings it will give a false positive and set off the ABS pump. This vibration/pulsation occurs only at low speeds and can be rectified by cleaning the sensor.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
- 15 Replies
- 7239 Views
Last post by WarbirdPilot91
- 16 Replies
- 3334 Views
Last post by precopster
- 20 Replies
- 6324 Views
Last post by oragex
- 509 Views
Last post by aharres
- 26 Replies
- 5987 Views
Last post by bmdubya1198
