1988 760GLE OD Fuse
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
DeRail
Year and Model: None
1988 760GLE OD Fuse
Post by DeRail »
Hey ladies and gents,
Just got an 88 760GLE last thursday. 111K miles on it. Here's the problem:
Last night I was just driving through the city and it was a little chilly, so my buddy turned on his heated seat. (Just a note on the heated seats: I noticed that the passenger side switch lit up when it was switched, the drivers side didn't, perhaps there's a ground fault on the driver switch) Well, about 2 minutes later, the orange arrow came up on the dash indicating that overdrive had kicked out. Also, his heated seat had shut off, the power seats wouldn't move, and the windows and sunroof were disabled. I figured it was just the #14 fuse, so I threw a new 10Amp fuse in the fusebox today, and it blew it the second I turned on the car. Just for giggles, I tried another new one, same thing. Since the car is only a few days old to me, I called the seller, who is a mechanic, and he said he will take a look at it. Is there anything that I can give him a heads up on when I bring him the car to look at, or anything I can try in the meantime?
Thanks
Derail
sseir39
Post by sseir39 »
The wiring under the car and near the transmission tends to disintegrate and shorts out easily. You need to get the car up and check the wiring to the OD solonoid first. You can replace it or tape it if it is grounding out.
Hope this helps, but it is the first place to look.
DeRail
Post by DeRail »
Okay, I will check out the wires going to the solenoid and let you know what happens.
Thanks for the help 8)
DeRail
Post by DeRail »
Okay,
I'll be throwing the car up on a lift tomorrow and I haven't ordered my Haynes manual yet :oops: . Does anyone happen to have a diagram that shows where the OD solenoid is located?
Thanks a lot!
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 483 times
Post by jonesg »
DeRail
Post by DeRail »
Thanks jonesg for the diagram
I took a look at the wiring under the car and the stuff around the solenoid still looked insulated pretty well. There were one or two bare spots in the cable around the shifter end. I patched those up but the darn fuse is still blowing. I looked at my fuse diagram again and found that the heated seats appear to be on fuse 35, but there's no fuse 35 in my fusebox so I thought that maybe it was behind the ashtray with the OD relay but I could not get the center console to slide out, it was being restricted by the plastic running around the shifter. More importantly though, I'm wondering how heated seats, on a different line than overdrive could have taken it out, unless the short is where the OD relay is sitting?
Thanks for the help
Darrell
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
By this I assume your fusebox is on the left side of the instrument panel. There should be 35 fuses - 2 outer rows of 10; a centre row of 13 and #34 & #35 mounted at the top of the plate, both rated at 30 amps.
This is from the owner's manual:
Note: Fuses No. 34 and 35 are circuit breakers which activate when overloaded. After 20 seconds, the circuits should have cooled down and function normally.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
DeRail
Post by DeRail »
Cheers Bill, that cleared that up :)
I did notice something that I did not before, however. When I turn the key to position two, I hear a *click* *click* coming from what sounded like the same general place as the solenoid. Is that normal for it to do that, or could the solenoid be toast?
Also, there is a relay tray behind the passenger kick panel. Does this house the OD relay in the 760's? I've read that the 740 relays are behind the ashtray but is it different on the 760's?
Sorry, I'm new to this :oops:
Thanks
Darrell
billofdurham
Your relay panel is behind the kick panel. 740 fuse/relay panel is behind the ash tray and much easier to access.
Relay listing:
A. Headlight relay with bulb malfunction indicator.
B. Fuel pump relay.
C. Central locking relay.
D. Foglight realay.
E. Headlight relay with bulb malfunction indicator.
F. Bulb failure sensor.
G. Overdrive relay.
J. Power relay.
K. Intermittent wipe relay (tailgate - wagon only).
L. Intermittent wipe relay (windscreen).
M. Seat belt reminder relay.
Is this coming from the solenoid on the side of the gearbox or from the location of the relay?
Bill.
Previously:
DeRail
Post by DeRail »
It sounded as though it was coming from the solenoid on the gearbox. I had the relay uncovered and it didn't seem to click at all.
On a side note: to diagnose if it is the relay, could I just pull the relay and drop a fuse in or would having no relay in the tray stop the flow of electricity to the other accessories on the line?
Cheers,
Darrell
