1984 240 GL Turbo will not start
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Not so Swede
Post by Not so Swede »
I am unable to start the car after running out of gas. I put gas in but still no go. I sprayed Fast Start (or a similar product) into the carburetor; still nothing. I then poured some gas directly into the carb; again, will not start. The engine turns over. I have electrical power (windows, lights, etc.). The odometer doesn't work but I suspect I have close to 200,000 miles on the car.
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 483 times
Post by jonesg »
Pull the plugs, check for spark and wet plugs.
If wet remove all the plugs and blast it out for a few seconds.
I wonder if there was water in the bottom of the tank?
Its also possible you burned the fuel pump then flooded the cylinders when you injected fuel yourself.
