My 92 245 will not engage into fourth gear. The OD light comes on and off whenever i depress the OD button, but most of the time the OD will stay stuck (no light on). It just wont shift into fourth?
Does the solenoid go bad/stuck activated?
Thanks,
Vic
1992 245 transmission wont shift into fourth gear (Automatic
2008-20016 XC70 - Is Buying One a Good Idea?
- Has thanked: 17 times
- Been thanked: 35 times
If it never does, it could be the relay or the wiring near the shift boot...sometimes it gets chaffed. Mine on the '91 240 will go into OD when warmed up but not before- I suspect the solenoid and will need to either replace it or bore it out (then it always will shift into OD, but no shifting down).
Mine does the same thing and I believe it's the solenoid.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Thanks Bill...I need to do this with mine.
Since it's intermittent and tends to work when the car is warmed up I'm leaning away from the relay and towards the solenoid.
- 757 Views
Last post by lummert
- 1086 Views
Last post by wizechatmgr
- 1132 Views
Last post by racertim
- 1809 Views
Last post by IslandV70
- 12 Replies
- 3544 Views
Last post by misha
